Are there Power Steering Cooler kit for 94 LS400??
Are there Power Steering/Transmission Cooler kit for 94 LS400??
Please suggest the right Power Steering and Transmission Cooler Kit for 94 LS400. While searching I found there is very common problem on LS400 regarding Power Steering. My had problem at 110K "Power Steering Leak", after do it yourself rebuild. I think the power Steering fluid is running very hot and do not want to rebuild Power Steering soon.
I found the below URL but not sure for my car.
http://www.derale.com/powersteeringcoolers.shtml
Thank You.
Thank You.
Found Transmission Cooler Kit
I found Transmission Cooler Kit for my 94 LS400 at Kragen Auto Parts Store.
The kit cost $30.00 it's Imperial Econokool model 242009. It's little touchy to install but it can be done.
I used Solder to make hole for the transmission hoses on the inner plastic piece that mount the bottom part underneath of the Radiator so I can locate the Cooler behind the license plate, and used plastic tie cable to secure the cooler.
Well I am trying to do the same for power steering but I think it tough to find space for the cooler kit.
