changing four o2 sensors ls400 model 2000
Old 06-03-15, 03:29 PM
akswagga
akswagga's Avatar
Default changing four o2 sensors ls400 model 2000
Ls 400 model 2000
Im thinking about changing the o2 sensors all four of them ( cause when they were cleaned the car performance was there for a day or two )
But the problem is the four sensors at my local dealer is around 636dollars all four sensors
So im wondering if if i should buy them online or should i just get them here ?
Online im having trouble finding a site that ships to bahrain
I found this one
[link removed]
But they didnt mention if its for the right side or left side before or after the
Or they're the same ?..hmmm?!
Last edited by PureDrifter; 06-03-15 at 04:08 PM. Reason: removed censor bypass on link.
Old 06-03-15, 04:09 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
please do not post links to that site as they have been censored on this forum. Find another website to try to post links from.
How did you "clean" the o2 sensors? They are not meant to be cleaned and doing so usually ruins them.
Old 06-03-15, 04:25 PM
UNCNOR
UNCNOR's Avatar
Try rockauto.com.They carry the Denso O2 sensors.
Old 06-03-15, 06:28 PM
oldskewel
oldskewel's Avatar
If you're trying to save some Dinars and don't have any CEL codes, I think you should be able to skip replacing the two post-cat O2 sensors. They should not have any effect at all on how the car runs, as far as I know. The post-cat sensors are usually only used to set a code to indicate when the cat needs replacing.
Old 06-04-15, 05:15 PM
akswagga
akswagga's Avatar
I didnt clean them this guy at the shop done it
So what you think should i get new o2 sensors ?
After cat n before ? R they all the same im thinking before the cat r same n the ones after r same
Old 06-04-15, 06:02 PM
timmy0tool
timmy0tool's Avatar
pre cat or "upstream" sensors are very different from post cat or "downstream" sensors!
left to right are the same however, meaning driver side upstream is the same as the pass side upstream, etc.
do you have a CEL? replacing sensors w/o a CEL is a waste of money, bc the culprit of poor performance isn't the sensors. it may be a variety of other things!
Old 06-05-15, 04:03 AM
akswagga
akswagga's Avatar
I had the cel light on before but after dey swap in two o2 sesnor its gone when i had the cel there was a delay in acceleration its better then before but i still feel it like the car is heavy and my average MPG 11.6
Old 06-05-15, 05:47 AM
billydpowe
billydpowe's Avatar
this might help you understand better
Attached Thumbnails changing four o2 sensors ls400 model 2000-systemoverviewverynew.jpg
Old 06-05-15, 02:11 PM
akswagga
akswagga's Avatar
Thx buddy ill see how it goes
Old 06-06-15, 02:01 PM
akswagga
akswagga's Avatar
So i found this site has them at a good price n shipping isnt bad
Denso sensors high quality ?
Staff sorry I couldn't edit the pic to hide the link on the photo on ipad there is no edit option
Old 06-06-15, 06:44 PM
UNCNOR
UNCNOR's Avatar
Take a look at rockauto.com pricing.I bought four Denso "pre-cats" for my two LS400"s and paid less than $40.00 each plus shipping.Good luck.
Old 06-06-15, 08:47 PM
sha4000
sha4000's Avatar
You can def. get those cheaper.
Losaun
GS - 1st Gen (1993-1997)
03-10-10 08:06 PM
Quick Reply: changing four o2 sensors ls400 model 2000
