99 LS Inner tie rod tool - 32.5mm ?
Can anyone tell me what the correct factory inner tie rod crowfoot (or adapter ) size is? I have Deeza replacement rods which measure 32.5mm but I don't want to assume they are EXACTLY the same as Lexus parts in that regard.
I can't measure the rods on the car without tearing off the rack boots and I don't want to tear off the rack boots until I have the correct tool.
Thanks!
Thanks!
Also, I don't know if you plan to do inner tie rod jobs for a living, but I would not spend the $$ on Snap-On tools for something I'm likely to do a few times.
Pep Boys, O'Reilly's, etc. rent (for free) those tools. And by the way, they have different brands. I used the Pep Boys one to do the removal (on a different car) and then found that my non-OEM replacement part needed a slightly larger wrench, so I went to O'Reilly's for that one.
