91' Ls400 electronic problem
Old 03-31-15, 09:01 AM
izmrpickel
izmrpickel's Avatar
Default 91' Ls400 electronic problem
Driving home from work in heavy traffic today and steped on my breaks and my car head lights went way dim and all my dash lights came on. I turned all my accessories off and limped it home thinking it was the alternator. I checked that and my battery and they are testing good. Alternator is putting our 13.66v @ idle and the batter tested fine and its from 06/14. It has not done it again but my head lights dim with lower engine rpms and with accessories on. And i noticed i used an 8th of a tank of gas when i normally use a 32nd of a tank to get home. I need help in finding why my car is doing this. Thank you -Matt
Old 03-31-15, 09:48 AM
lexmoose
lexmoose's Avatar
IIRC there's a wire harness in the trunk that can cause weird issue like this
I think this is it http://www.lexls.com/tutorials/lighting/bulbout.html
Old 03-31-15, 10:04 AM
izmrpickel
izmrpickel's Avatar
Ironicly one of the problems in that link i have had since i got the car. The tail light indicator comes on every so often but i don't ever have a bulb out. I will take a look at that wire harness. Thank you.
Old 03-31-15, 02:00 PM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus.
Do check the wiring harness on the trunk hinge. This is related to similar symptoms that you've described when braking or the rear lights.
aymaddemir
10-22-18 11:44 PM
GRAMPZ
12-29-14 10:46 AM
RRocket
02-23-13 11:27 PM
5ofakind
02-04-13 09:15 PM
JDPeppers
12-05-06 01:57 PM
Quick Reply: 91' Ls400 electronic problem
