Lexus LS400 Gear Selector plate or cover or whatever it is called.
Hi CL,
I have a question. My Lexus did not come with the gear selector cover or plate or whatever it is called and I have trouble figuring out what exact part number I need for this. You can see into the gear section as you can see in this pic:
I have here this diagram with part numbers and I am thinking that part number 35954 is what I need. Can you tell me if this is correct? Hopefully it will no be too difficult to do this. Strange that it is missing in the first place... This is my first Lexus so I have no idea about this aspect.
Thanks in advance for your help.
I can get it new from Lexus but you're right. It might be expensive. Is it a complex job to refit it? I don't understand why it wouldn't be in my car in the first place...
The previous owner probably lost it when doing some work. It's not a difficult job but you would have to remove the wood trim there. It pops off but you have to be careful not to break the tabs that hold it down. Then you have to disconnect the connectors in back of the ashtray. This will give you access to the shifter. Oh and you need to unscrew the top of the gear selector off.
motoguci
GX - 1st Gen (2004-2009)
07-20-10 05:41 AM
DivX007
10-16-07 11:57 AM
