rear diff movement?
Old 03-03-15, 04:35 PM
dc893
dc893's Avatar
Default rear diff movement?
How much should the rear diff move when it is put into D? Mine moves up pob about an inch. When putting the car into D it makes two loud pops coming from where the axle goes into the diff on the passenger side.
Old 03-03-15, 05:01 PM
timmy0tool
timmy0tool's Avatar
sounds like your diff mounts are compromised. there should be deflection but not by much. popping could be bad axles.
how did you find out? you were under there while someone put the car in gear?
Old 03-03-15, 05:40 PM
dc893
dc893's Avatar
Under as little as possible while the gf put it in gear. Went back under and the front diff mount is def bad. Just trying to find the right bushings and see how hard it is to change. Really hoping thats the issue.
Old 03-03-15, 06:54 PM
timmy0tool
timmy0tool's Avatar
common as the rubber deteriorates. they do make solid mounts, but that would horrendously vibrate!
Old 03-04-15, 12:29 PM
dicer
dicer's Avatar
I don't know for sure, but I would think one of the main causes for those bushings to go bad, is trying to drive these cars like race cars which they are not. If it is driven like the old granny car that it was meant to be things should last for a very long time. Well except for the front suspension that doesn't seem to last for a granny either. Rapid acceleration starts would not be good on the stock rubber bushings nor on the rubber ujoints.
Old 03-05-15, 06:38 AM
dc893
dc893's Avatar
Got the parts ordered. Just gotta look an see how hard this will be.
I think over 300k miles might put some wear on that bushing or the last owner drove the heck out of it.
Old 03-23-15, 09:01 AM
dc893
dc893's Avatar
Got the bushing installed no more thump when putting the car in gear.
Old 03-25-15, 07:18 PM
timmy0tool
timmy0tool's Avatar
good to hear, was it hard to press in?
Old 03-25-15, 08:10 PM
wonderb
wonderb's Avatar
This is interesting. I've been having a problem with the trans(or what I thought was the trans) "popping'
and bucking a little forward(or back in R) no matter how hard I have my foot on the brakes. i just assumed the trans was on it's way out and needed a rebuild or something. Think I'll have a look at the diff mounts and axles in general after reading this, thanks for bringing this up.
Old 03-25-15, 09:05 PM
sha4000
sha4000's Avatar
Check the actual transmission mount first.
Old 03-26-15, 10:52 PM
wonderb
wonderb's Avatar
Thanks for the tip.
Did while I was doing the gasket/filter awhile ago (was hoping a fluid change would help the situation), looks pretty new actually, think the previous owner may have had it done. in any case no sign of tearing or wear on it.
Old 03-31-15, 05:58 PM
dc893
dc893's Avatar
I didn't do it because I wasn't sure how difficult it would be. I was able to watch the mechanic and it didn't look bad. Only took him a total of 30 min to remove and install. The only symptom was a thunk into D. R was just fine.
Old 04-01-15, 05:43 PM
timmy0tool
timmy0tool's Avatar
Thanks for the tip.
it may not look torn but could have broken at the very bottom. mine looked fine but broken into two pieces when removed!
Old 04-02-15, 08:54 PM
EENCIZO
EENCIZO's Avatar
Can you post the part number please?
GarageB
IS F (2008-2014)
11-23-16 06:25 AM
ls400love
Suspension and Brakes
07-24-14 07:05 PM
mk4r34
Performance & Maintenance
09-13-12 09:12 AM
aporozco
01-02-11 06:20 PM
Luv Da Lex
07-11-06 08:24 PM
Quick Reply: rear diff movement?
