93 LS400 Engine Temp Indicator at 40%
Old 03-04-15, 09:39 AM
tomgadgets
tomgadgets's Avatar
Default 93 LS400 Engine Temp Indicator at 40%
Got my LS400 a few months ago, fantastic car and drives like a dream. One question on the engine temperature indicator maxes out at around 40%, which is right at the indicator mark below 50%. It never moves up beyond that no matter how much I drive. If I drive on the freeway at 60-70Mph, the temperature needle will actually drop down to around 30-35% and when I slow down or stop, the indicator will go back up to 40%.
Does your 90-94LS do the same thing, or should I change the thermostat? I have already changed the Engine Coolant Temp Sensor and it made absolutely no difference.
Thanks in advance for your response!
Old 03-04-15, 10:32 AM
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
Sounds normal to me.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
Old 03-04-15, 11:02 AM
2GSKaizen
2GSKaizen's Avatar
I would check to make sure you have enough coolant, but if so I don't think you've got a problem.
timmy0tool
timmy0tool's Avatar
yep, normal. if it gets to 50% i would be concerned!
Old 03-04-15, 07:19 PM
tomgadgets
tomgadgets's Avatar
Good to hear it is normal, the coolant was changed about 2 months ago so no issues there. Was going to spend $$ to change the thermostat. Thanks for your response!
Old 03-04-15, 08:44 PM
qewani1
qewani1's Avatar
It is not normal, your thermostat is stuck open, i was having exactly the same issue 2 weeks back...
Check your thermostat and replace it if required
My problem solved by replacing the damaged thermostat!
+ Don't buy an aftermarket thermostat !
Normal temp reading would be in the middle which is = 86 Celsius
Old 03-04-15, 10:35 PM
MngreLMatt
MngreLMatt's Avatar
At highway speeds it is dropping down that much? I'm no expert but that does not sound normal. The normal for these cars or at least on our 3, is just a hair about the 40% ticker or third from the bottom.
Mat
Old 03-05-15, 09:58 AM
tomgadgets
tomgadgets's Avatar
Yes, when driving in the highway, it will drop down to 30% and will move slowly up to the 40% mark if I slow down or stop. Very strange as I never seen this on any of my other cars. Thanks for your input, I am going to bring it to my mechanic and have a more detail look.
Old 03-05-15, 12:10 PM
timmy0tool
timmy0tool's Avatar
when was the last time the thermostat was changed? usually it's done during the 90k timing belt/water pump service. if it was never done, it would not hurt to do so.
Old 03-06-15, 09:34 AM
tomgadgets
tomgadgets's Avatar
Not sure when was thermostat last changed. The timing belt was changed 20K miles ago in 2009. Maybe it is time for a new thermostat.
96UCF20
13
06-12-16 06:07 PM
Jlacck
32
02-25-15 06:32 PM
nervekiler
01-14-10 10:00 AM
chrisngo
10-19-08 04:06 PM
Quick Reply: 93 LS400 Engine Temp Indicator at 40%
