Gas tank location 93 Ls400?
Old 02-13-15, 06:39 PM
630's Avatar
Default Best for
Old 02-13-15, 06:53 PM
GH5T
GH5T's Avatar
Between the rear seat back and the trunk.
Old 02-13-15, 07:15 PM
dicer
dicer's Avatar
You gain access to it by removing the front trunk panel, there is a steel wall behind the rear seat back.
Old 02-14-15, 05:46 AM
lexmoose
lexmoose's Avatar
Here's a pic of mine (96), but should be very similar to your 93
You will not hit the gas tank, but you should still lift the car to make sure you don't hit something else.
You can use the seat-belt bolt as a reference point to measure the exact location of where you want to drill.
Old 02-14-15, 12:25 PM
dicer
dicer's Avatar
Not much under the seats and floor to hit, brake lines and gas lines would be a concern, just look before drilling. And if you ever go to sell it please put in the ad " I drilled some extra holes in the floor" That should make it a very desired car to buy for the next person.
ohhsoo
05-10-13 08:20 AM
ehaze
05-11-12 01:25 PM
Ncrowe
08-28-08 10:11 PM
ninetwosc
10-09-07 08:58 PM
will33184
12-20-05 09:12 AM
Quick Reply: Gas tank location 93 Ls400?
