Keys
Old 03-12-03, 04:26 PM
katz
katz's Avatar
Unhappy Keys
Can somone please tell me what the small buton on door Key of my 94 LS is supposed to do? I press it and nothing happends I even changed the battery located inside the key and still nothing. What is the botton for? There is nothing in the manual about it either. Can anyone please explain. Thanks
katz.
Old 03-12-03, 05:09 PM
spxChrome
spxChrome's Avatar
That button on your key is used for the remote keyless entry. (lock/unlock doors and turn on the security system)
If this is a used key from another car that was cut for your car it won't work.
If it is the original key for the car then check to make sure you have remote keyless entry turned on. To the left of the steering wheel you will see the switch.
If the lock/unlock works but you don't hear the beep(s) then check under the dash on the same side. There is a dial you can use to turn the beep volume up, down or off.
Old 03-13-03, 02:56 PM
katz
katz's Avatar
Thumbs up key help
Thanks for you help. I surprised the manual dosent mention anything about the button.
Old 03-13-03, 05:01 PM
rajah996
rajah996's Avatar
Hey guys,
where/what does this dial look like? I have always wondered why my car
does not have some sort of chirp or light flash for the keyless entry. Please
help me out as this has concerned me for the last 18 months that I have
owned the car
thanks
-R
Old 03-13-03, 05:26 PM
spxChrome
spxChrome's Avatar
It's under the dash to the left of the steering wheel. get down like you are looking for the fuse box and look up you will see it. u can turn the dial for volume or you will here it click to turn it off.
to the right of the dial you will see the plug to run diagnostics. you can't miss it.
Old 03-13-03, 06:24 PM
rajah996
rajah996's Avatar
Thanks SpxChrome!
I will try it out first thing in the morning. Hope it works, *fingers crossed*
-R
Old 03-13-03, 07:05 PM
dbullen
dbullen's Avatar
Originally posted by rajah996
Hey guys,
owned the car
thanks
-R
Is this a feature just on the 93-94 LS400's? I can seem to find a dial on my 92.
Old 03-13-03, 07:08 PM
rajah996
rajah996's Avatar
I hope not, I have a 92 myself also. I will take a look in the morning and let
you know if I can find it in my car.
-R
Old 03-14-03, 04:43 AM
TomWahjudi
TomWahjudi's Avatar
On my '95, there is only a small black button that turns on/off the beep, but I'm not aware of being able to set the volume.
Old 03-14-03, 06:31 AM
Lvangundy
Guest
Posts: n/a
I know for a fact 1990-1992 models didn't have a beep or flashing lights.
I'm also pretty positive 1993-1994 didn't either. I think the beep was added in 1995. (maybe 94)
As far as I've read and been told by the dealer, 1990-1992 had a different kind of lock system than 1993+.
Old 03-14-03, 06:51 AM
spxChrome
spxChrome's Avatar
My 93 LS has it. 1 beep to lock, 2 to unlock with volume control under the dash.
Old 03-14-03, 12:01 PM
rajah996
rajah996's Avatar
Unfortunatly you guys are correct. When I got under the dash of my car this
morning I could not find the switch/dial. Oh well, I am probably putting remote
start in the car in a few weeks, so that will have an alarm that chirps. Thanks
for your help anyways.
-R
Old 03-14-03, 12:18 PM
spxChrome
spxChrome's Avatar
I can't imagine why my 93 has it and your 94 doesn't, but if it ain't there it ain't there.
Old 03-15-03, 04:21 AM
dbullen
dbullen's Avatar
I believe rajah996 has a 92.
Old 03-15-03, 10:28 PM
rajah996
rajah996's Avatar
Hey guys, Yes my LS is a 92. I really wish now I had bought the 93
i was comparing mine to. Oh well, we all have 20/20 vision, lol.
-R
hlippy4
11-07-18 08:56 PM
creilly
13
07-27-17 07:20 AM
houndawgbp
GS - 1st Gen (1993-1997)
02-02-14 03:00 PM
VQT
08-04-07 03:39 PM
drsaab1
02-15-06 07:04 PM
Quick Reply: Keys
