HELP-car cutting off while driving
Old 03-09-15, 10:10 PM
  #91
dicer
dicer's Avatar
It must still be in the shop?
Old 03-09-15, 11:11 PM
  #92
RA40
Super Moderator
RA40's Avatar
When this is a continuation of the same issue we like to keep it in one thread. This allows future searches to detail each step rather than jumping from thread to thread to find what the results were.
Merging this with the prior thread.
Old 04-26-15, 02:51 PM
  #93
LS400BOY
LS400BOY's Avatar
Been in the shop for about a month now,they say its Probly the computer because its not responding to the key and not telling the fuel pump to cut and stay on
Old 04-27-15, 02:23 AM
  #94
dicer
dicer's Avatar
That would be a fun project to work on, I wish it was close.
Old 04-27-15, 02:27 PM
  #95
LS400BOY
LS400BOY's Avatar
Yea tell me about it,they said they still tracking wires,im still thinking it has to do with it when we bot the lower ball joint and hit the ground hard then it been giving us problems since' then
Old 04-28-15, 02:09 AM
  #96
dicer
dicer's Avatar
I'd know for sure if it was the ecu, cause I'd put in a known good one, after checking everything else out first.
If they ever find the problem I bet it is something simple and over looked. Or just not tested correctly.
Old 04-28-15, 07:41 AM
  #97
LS400BOY
LS400BOY's Avatar
So is it best to get another used ecu? Do you have to get the matching key from same car as ecu??? Does the ecu have to be flashed the it be ready to installed?
Old 04-28-15, 01:00 PM
  #98
dicer
dicer's Avatar
Gen 1 is all plug n play. The locks recognize the keys just old normal stuff. The remote is done by the remote ecu in the trunk. Yeah try a KNOWN good ecu. And NO its not best to get another USED ecu, it has to be known to work good, like out of a car that is running good. The only thing important is that the ecu is for a TRAC or NON TRAC what is yours?
OH and did the shop check for the ignition signals from cam and crank sensors? Remember it shut off while driving, the ecu needs that signal to keep fuel pump running.
Old 04-28-15, 05:06 PM
  #99
aptoslexus
aptoslexus's Avatar
Originally Posted by LS400BOY
Hello all,the wifes car 92 ls400 just cut off on her while driving to work and it wont start back up feels like it catches for a sec but wont stay on,i remeber her running out of gas a month or so and said it cuts off on her from time to time, could this be the fuel pump went out? Should i start with the fuel filter? Or is there anything else that could cause this? Desperately need help fellas
Seems basic, but did you check the battery cables? A loose cable will give you those problems.
Old 05-20-15, 05:45 AM
  #100
LS400BOY
LS400BOY's Avatar
Originally Posted by dicer
Gen 1 is all plug n play. The locks recognize the keys just old normal stuff. The remote is done by the remote ecu in the trunk. Yeah try a KNOWN good ecu. And NO its not best to get another USED ecu, it has to be known to work good, ulike out of a car that is running good. The only thing important is that the ecu is for a TRAC or NON TRAC what is yours?
how would i know if my car us trac or none trac? So whatever car i get it from has to be the same correct? So just need the computer.in the front not in the trunk right
Old 05-20-15, 01:31 PM
  #101
dicer
dicer's Avatar
Trac will have a button just above and to the left of the ash / cash tray. ECU is under the glove box.
Anything from trunk is an option, nothing there other than a gas tank that is for engine related stuff.
Old 06-08-15, 02:43 PM
  #102
LS400BOY
LS400BOY's Avatar
Ok i got a call from the shop finally this morning and basically said it was the key? Something about the mobilizer? or immobilizer? In the key was bad he said i need a new key, does this makes sense guys for my situation? So if i got a new key mad it will crank right up??
Old 06-08-15, 07:10 PM
  #103
Yamae
Yamae's Avatar
Lol. Does a 92 LS have a immobilizer?
Old 06-08-15, 07:51 PM
  #104
PureDrifter
BahHumBug
PureDrifter's Avatar
no, they don't.
in the US market, at least.
Old 06-08-15, 08:49 PM
  #105
LS400BOY
LS400BOY's Avatar
So wtf man lol so getting a new key is not the solution then? No mobilizer??? Huh what so the shop full of ish then! Im so fed up with this car,mite go to the junkyard
Quick Reply: HELP-car cutting off while driving
