Steering End
Old 12-29-14, 08:45 PM
MattLS400
MattLS400's Avatar
Default Steering End
Season's greetings.
96 LS400
Can anyone confirm whether these part numbers for the following steering tie rod end are correct ?
OUTER TIE ROD ENDS
Manufacturer Part Number:
left -4546059015
right - 4547059015
Inner Tie rod ends P/Ns needed
thanks
Old 12-29-14, 11:53 PM
dicer
dicer's Avatar
4550339095 and both the same LH and RH and attach the rack. Your numbers look good.
And this is 1st gen stuff.
Old 01-10-15, 04:57 PM
MattLS400
MattLS400's Avatar
Exclamation
Thanks dicer.
The attached is the left inner tie rod end from my car. Yes it needs changing urgently.
However, I am only seeing right inner tie rod ends available. My question therefore is whether these tie rod ends are interchangeable, that is can the right inner be used for the left inner ?
thanks in advance.
Old 01-11-15, 12:15 AM
dicer
dicer's Avatar
Same number same part ?
Old 01-11-15, 06:28 AM
MattLS400
MattLS400's Avatar
The above inner end came out from the left side of my ucf 21. From my research it seems as if this was for the right side. I need to know the correct placement. thanks
Old 01-11-15, 10:22 PM
dicer
dicer's Avatar
http://lexus.sewellparts.com/oem-cat...S400-1992.html
I was just going by the parts book. I could be wrong, so here you go. This is for 92, what year is yours?
That longer wrenching area looks like the LH one in the parts book. I don't know why they give the same number for both sides.
Old 01-12-15, 03:56 AM
MattLS400
MattLS400's Avatar
Dicer, thanks. I have a 96 Ls400
this is the schematic for my 96
Old 01-12-15, 07:58 PM
sha4000
sha4000's Avatar
That is indeed the right inner tie rod end since it states that's the side that the right outer tie rod end goes.
http://www.lexussouthatlantaparts.co...rimLevel=19107
Old 01-13-15, 10:16 AM
timmy0tool
timmy0tool's Avatar
right and left have different part numbers. in the sewell pic you are pointing to the right inner tie rod.
Old 01-13-15, 03:11 PM
dicer
dicer's Avatar
Sorry I didn't catch the 96 in your first post. That picture clears it all up. I need to wake up before I post info. even had my left and right goofed up.
Old 01-13-15, 06:33 PM
MattLS400
MattLS400's Avatar
Thanks guys, I needed that confirmation.
I can therefore clearly say that the previous owner's mechanic installed the tie rod ends on opposite sides.
i.e the right inner tie rod end is on the left of my vehicle
the left inner tie rod end is on the right of my vehicle.
Im guessing this can be one of the major causes why my LS400 drifts on the road? even after allignment...?
Old 01-14-15, 03:36 PM
timmy0tool
timmy0tool's Avatar
if the alignment shows zero toe, i don't see how a difference in tie rod inners will matter during the drive. what i do see being affected by the opposite swap is the lock left to lock right distance since something was compensated to account for the longer inner rod.
what i also noticed after looking at the pic is that your inner rod is slightly bent!
Old 01-17-15, 08:08 PM
MattLS400
MattLS400's Avatar
Thanks guys. Your guidance was correct. However, It was my fault not to mention that my car is 96 Celsior which means that it is a RHD. Therefore, it was correctly in place at first. So for future reference guys, the left inner steering end of a Celsior would be the right inner steering end of an LS400, similarly the right inner steering end of a Celsior would be the left inner steering end of an LS400.
Rozay604
09-01-23 03:54 PM
jdanielca
09-06-18 05:50 AM
crazy8ship
03-21-16 08:04 AM
mk4r34
SC- 1st Gen (1992-2000)
03-18-10 02:55 PM
Quick Reply: Steering End
