Ucf20 ride height
Old 12-21-14, 11:08 PM
mattylex77
mattylex77's Avatar
Default Ucf20 ride height
Searched and didn't discover anything. I have a 99 with 96k on it. Shocks have Kyb stickers on them and don't appear to be blown at all, so idk if they are factory or replacements I haven't measured yet but unladen and with very little gas in the tank the gap between the tire and fender in the rear is decidedly smaller than in the front. It makes for an unbalanced feeling car and a stance that doesn't look good. Alignment seems good even though I need new strut rod bushings. so my q is does any one have factory specs for the fender gap on a ucf20/ what might be causing this.
Old 12-22-14, 08:02 AM
sha4000
sha4000's Avatar
I believe you can find the specs in the owners manual that you keep in the glove compartment.
Old 12-22-14, 10:11 AM
RA40
Super Moderator
RA40's Avatar
I have measurements of mine before lowering...will dig through some of the records and post. The front gap is about 2-1/2" to 3" and rear is 1-3/4 to 2-1/4" roughly. Yes, it will be uneven from side to side. I posted the measurements in a thread somewhere here but I cannot easily find it since this was back in '04'ish.
Old 12-22-14, 11:15 AM
mattylex77
mattylex77's Avatar
So you're saying the front gap should be a bit wider then. Don't know why I was under the opposite impression. Thx for the input
Old 12-22-14, 12:22 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the bounce test is a better indicator of if your shocks have blown. the OEMs have KYB etched into them iirc so that's not a good indicator.
Old 12-24-14, 06:37 PM
mattylex77
mattylex77's Avatar
i have done the bounce test and they feel like brand new. they have stickers on them not etchings. im just worried they installed the rear shocks on the front and the fronts on the rear.
Old 12-25-14, 01:32 AM
PureDrifter
BahHumBug
Extremely unlikely but you can alwayscheck the part numbers on the stickers to confirm.
Old 12-25-14, 10:52 AM
sha4000
sha4000's Avatar
I highly doubt that they were installed incorrectly but anything is possible. I have literally no gap in the back and a small gap in the front with new KYB GR2s and Eibach lowering springs.
RogueRG
Suspension and Brakes
08-06-12 11:30 AM
c4lvin
06-28-10 06:59 AM
smoltz
01-24-10 12:11 PM
jet119
33
08-07-07 10:06 PM
DASHOCKER
10-17-05 12:19 PM
Quick Reply: Ucf20 ride height
