Front end metal scraping sound
Old 12-21-14, 05:46 PM
BIGWHITESC
BIGWHITESC's Avatar
Default Front end metal scraping sound
I have a 94 ls400 very low and aggressive. When rolling I can head a metal scraping noise like shhhh..shhhhh.shhhh. Like it goes with the speed of the wheels. It's not the brakes or the brake shield. Could it be wheel bearings from -7 camber in front? had car on lift and did the normal checks for excessive play up/down left/right. Did feel off and had no play. Spun every wheel and listened for anything and still nothing.
Old 12-21-14, 07:48 PM
sha4000
sha4000's Avatar
Is it rubbing against the wheel well liner?
Old 12-21-14, 09:58 PM
BIGWHITESC
BIGWHITESC's Avatar
all the liner is removed
Old 12-22-14, 01:32 AM
dicer
dicer's Avatar
Make it stock height and likely the sound will magically go way.
Old 12-22-14, 07:29 AM
YoshiMan
YoshiMan's Avatar
Have you actually physically checked the brake pads?
Old 12-22-14, 07:42 AM
sha4000
sha4000's Avatar
Do you have a cut out for the upper control arm.
Old 12-22-14, 12:30 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
probably bearings or pads, especially if you have slotted rotors.
When you go that aggressive in setup it will be harder on the bearings.
Offspring
10-24-18 12:43 PM
OMLooper
08-31-18 12:32 PM
willyc
Suspension and Brakes
06-23-08 06:31 PM
vertcobra9
04-10-08 01:10 PM
SilverLexo
04-17-04 06:50 PM
Quick Reply: Front end metal scraping sound
