Striaght pipes through and X-pipe installed
VIP 様式
Exhausts done. Striaght pipes and X-pipes installed
This is the set up I went with. It still sounds the same as it did when I removed the two middle mufflers, but now there is a slight whine to the sound, much like a mini supercharger in a way. As far as performance goes the car moves quicker through low and mid rpm. Also what I notice is that when I let go of the gas the speed does not decrease as fast and the speed pretty much goes down little by little even though my foot is off the pedal.
I did make a 1min. movie on how it sounds, but everytime I load the vid. It screws up my comp
This a picture of the setup from Planet Soarer. I did everything except the high flow cats and I decided not to have the sharp curve at the end and keep it straight all the way through until the end instead. I stuck with the front two stock cats and got rid of the middle stock cat for the X-pipe. The sound now is much more cleaner with a deep growl and slight whine to it.
VIP 様式
Here is the best pic I have with my new setup, still not very good though. The car was already jacked up, but I did not want to go any higher for my well being. The pic is upside down.
Originally posted by Lexozz
How does it sound?
How does it sound?
VIP 様式
How does it sound?
How does it sound?
Like LS400 said sounds almost just like the So.Cal meet vid, but much more cleaner and a little more whine to it.
Hey how much did this whole setup cost? I was thinking of copying the exact setup, except I was re considering doing the cats as well. How much is it for the two cats if you were to do it? Good choice in setup, what muffler did you choose?
VIP 様式
Originally posted by jbrady
Eric, nice work, it looks well thought out.
What size pipe? 2.25" or 2.5"
Did you buy that X-pipe or did the shop fabricate it?
The only set back is a little noise during idle, but it is no biggie.
I also have a few more goodies to work with later this month. A injen intake, I am probably just going to use the pipe if it still needs a MAF adapter and a set of JIC coilovers should be here any minute. Hmm dunno whats next, Torque converter or LSD? maybe, but I do not know right now, but I have something at the end of the year that will be special for the VIP celsior lovers to look at
here is a picture of the right muffler from my old pipping before the X-pipe route (rear view)
VIP 様式
Originally posted by kenjitsou
Hey E..........What kind of mufflers are u running? Can't be Remus rite?
j.k
They are Tsudo universals. I like them because they are pretty hollow and wont restricted any airflow.
Originally posted by CelsiorUCF10/11
Yes they are Remus exhausts
j.k
j.k
