help car turn off and wont turm back on
Old 06-25-14, 12:10 PM
305ls400
305ls400's Avatar
Default help car turn off and wont turm back on
i was driving my car yesterday about 120 miles, the car was working great all day no problems nothing wrong the whole day i park the car to go inside for 20 minutes, i left the car on i came back and the car was off, try to turn it back on and nothing happen i change the battery thinking it could be the problem but nothing, can anyone help my with ideas of what it could be.
Old 06-25-14, 02:55 PM
RA40
Super Moderator
RA40's Avatar
Not sure I'm reading it right: left the car running for 20 minutes and when you came back it was off and wouldn't start or run?
Out of gas-dead fuel pump from going dry.
Starter dead
What year how many miles?
Does the car crank as in starter works?
Plug in to get codes.
Old 07-01-14, 09:57 AM
305ls400
305ls400's Avatar
yes i park the car and it was on , did not turn it off i left the a/c on so it can be cold when i got back to the car. not the fuel it was full at the time. 1992, miles stop working on my car about 5 years ago with 175889 it should have around 350.000 or so about now i change the timing belt (water pump and everything in the area) 2 times all this years, spark plugs and cables with coils and caps, and the regular things nothing major
i dont know if it could be related but the e-break light will come on and off when i was driving.
Old 07-01-14, 10:29 AM
305ls400
305ls400's Avatar
no codes . new battery it
. started souds like it turn but the car doesnt not crank
Old 07-01-14, 08:43 PM
Yamae
Forum Moderator
Yamae's Avatar
Could you explain this more? What do you mean by e-break light?
Old 07-02-14, 06:09 AM
python
python's Avatar
huh? if its not cranking then its not turning over. if ur trying to start the car and u don't hear anything and the engine isn't cranking u may have blown a fuse under the hood or a fusible link. do the dash lights come on when u turn the key to the "ON" position?
Old 07-06-14, 08:14 PM
Boxcuta
Boxcuta's Avatar
Ignition coils. My car use to cut off driving down the road and eventually not start. Turn over but never crank. When the driver side went out apparently the car wouldn't crank. Replaced both and it worked. Check to see if you're getting spark. Hope this helps.
Old 07-07-14, 06:38 AM
305ls400
305ls400's Avatar
the emercengy break light will turn on without me applying the emercengy break, this will happen random, it will go away.
Old 07-07-14, 06:44 AM
305ls400
305ls400's Avatar
i check all fuses and everything is fine including the relay, this was the first thing i check because it happen to me before about 2 years ago and it was the relay. everytime i turn the key it sounds like the something is turning
Old 07-07-14, 06:45 AM
305ls400
305ls400's Avatar
i replace the coils spark plug caps and rotors about 6 months ago
Old 07-11-14, 10:50 AM
305ls400
305ls400's Avatar
the starter clicks but it wont turn also the negative cable on the batter got really hot and wite smoke. i check all the fuses
Old 07-11-14, 12:33 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
if the starter doesn't turn, then it sounds like the starter died.
Old 07-11-14, 12:47 PM
Legender
Legender's Avatar
white smoke from the negative battery cable... bad news. Need to replace that cable. Same happened to my dad's 93.. had a new cable made as the dealer price is outrageous. I bet you don't have good grounding from the cable therefore no complete circuit... at least not enough to get power to the starter.
Old 07-11-14, 01:43 PM
lexmoose
lexmoose's Avatar
yup like Legender said, sound like you have a bad "restrictive" ground.
Try with jumper cables to hook the negative (- sign) on the battery to a solid non-moving piece of metal on the engine (hook to lift the engine?) and try to crank it. If it start then you found you problem. Leave the positive (+ sign) alone, do not connect the jumper cable on the positive.
Also make sure you battery is charged, bad ground could also mean that the battery wasn't charging properly and now your voltage is to low.
Starter is also a possibility and cause short/over-current when cranking, but in your case this wouldn't have cause the car to stop, but a bad ground yes.
Keep us posted on your findings
Old 07-15-14, 10:50 AM
305ls400
305ls400's Avatar
i try with the jumper cables nothing happen also, the negative jumper cable got hot also. im going to change the starter and check the ground cables under the car
Quick Reply: help car turn off and wont turm back on
