1995 LS400 Problems.. Need help.
Old 04-12-14, 07:28 AM
RNH524
RNH524's Avatar
Default 1995 LS400 Problems.. Need help.
So I just got this 1995 LS400 on trade super clean car runs great and shifts fine if you drive it normal but These are the known problems I'm having..
- From switching from reverse to drive the car jumps
- Brake pad light in on
- The Trac Light is blinking.
- Today I gave it a little gas and barely had any pick up to it at all and once I did that the ECT POWER light is blinking...
Any help would be much appreciated. Thanks in advance.
Old 04-12-14, 07:38 AM
python
python's Avatar
95's are notorious for ecu issues
Old 04-12-14, 07:42 AM
RNH524
RNH524's Avatar
So what are you thinking it has a bad computer ?
Old 04-12-14, 08:20 AM
python
python's Avatar
its quite possible, search for the ripple test for further evaluation
Old 04-12-14, 08:34 AM
sha4000
sha4000's Avatar
Possible bad transmission mount for the jerk.
Brake pad wear sensors need to be changed or grounded for the light.
Remove the negative battery cable for a couple minutes to try and reset the ECU for the trac and poor performance maybe.
And like python said, there's a whole thread about the Bad ECU's.
Old 04-12-14, 08:42 AM
RNH524
RNH524's Avatar
Thanks guys I appreciate it. I'm gonna go try that out right now.
Old 04-12-14, 08:50 AM
zyzygy
zyzygy's Avatar
Had same symptoms on my 96, once the bad capacitors were changed it was functioning like a new car, follow the instructions on the ecu thread and you'll be ok.
Old 04-12-14, 09:21 AM
RNH524
RNH524's Avatar
I'm new to the forum.. where can I find that at ?
Old 04-12-14, 10:26 AM
zyzygy
zyzygy's Avatar
Heres the link:
https://www.clublexus.com/forums/ls4...capacitor.html
Check the second gen sticky, covers everything!
Old 04-12-14, 12:31 PM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus.
Python and sha4000 have you covered for your car's symptoms.
Old 04-12-14, 04:36 PM
RNH524
RNH524's Avatar
Should I just buy a new computer or just order the capacitors ?
Old 04-12-14, 05:07 PM
RNH524
RNH524's Avatar
Ok so I disconnected the neg. from the battery and let it sit for a couple mins and then started it back up again and that took away the blinking trac light& ECT Power lights but the brake pad light is still on which i figured it would be.. But this time when I started it it had a high idle at like 1300-1400 until I put it in gear than it would go down to a normal idle but if i put it back into park or N it would idle high again and it did that for a good 2-3 mins then the idle finally came back down to normal.. Didn't get to take it out for a ride to see if the acceleration was any better though.. So is that a good clear sign of a bad ECU ?
Old 04-12-14, 05:14 PM
python
python's Avatar
stalling is a huge concern for 95's. a bad ecu will have various symptoms..the yamae ripple test procedure will eliminate or prove that the ecu is the culprit...other than that u can remove and inspect the ecu
Old 04-12-14, 05:35 PM
RNH524
RNH524's Avatar
I haven't had any stalling problems.. It I drove it normal like just give it a little gas it runs perfect but its just when I floored it to see what kind of pick up it had it had none like it was hesitate and didnt want to go anywhere.
Old 04-12-14, 06:35 PM
sha4000
sha4000's Avatar
The idle is not to far out of spec but you might need to clean your throttle body. You also might want to check your transmission fluid level to see if it's too low.
Quick Reply: 1995 LS400 Problems.. Need help.
