Ordering Motor Mounts, What Else Should I Replace
Old 05-27-13, 09:56 PM
lhgdale
lhgdale's Avatar
Default Ordering Motor Mounts, What Else Should I Replace
Hello, I am about to order a new set of motor mounts for my 92 LS. I have read through alot of the threads about the install. What else should I change out since I am removing some of the steering/suspension parts (bushings..ect...)?
Any tips on the install are also much appreciated!
I will be taking the car for an alignment and tire balance once the install is complete.
Thanks
Old 05-28-13, 05:46 AM
johnnyg66
johnnyg66's Avatar
I am sure you may have done the tranny mount. Other than that easy stuff would be sway bay bushings and power steering rack bushings. As far as install just support it well and take your time.
Old 05-28-13, 09:40 AM
YoshiMan
YoshiMan's Avatar
Taking the steering rack out certainly makes it MUCH easier! The rack bushings are probably rotted as it is anyway.
Don't be afraid to drop the front crossmember too, i couldnt get enough clearance even with jacking up the motor. Its not too bad, just four big bolts and it'll come loose, and the struts hold it from just falling out of the car. I didn't have to touch the lower control arm adjusting bolts, it had plenty of movement on its own.
Old 05-28-13, 10:09 AM
billydpowe
billydpowe's Avatar
WARNING: it is very easy to damage the heater control valve when you jack up the engine....
Old 05-28-13, 05:10 PM
lhgdale
lhgdale's Avatar
Thanks for the info guys, I will order those bushing also.
As I said above I have read a few people's write ups on the install but is there a pic step by step post kinda like the ones on LexLs.com?
Thanks again for the info!
Old 05-29-13, 10:41 AM
sha4000
sha4000's Avatar
Just search using the keyword engine mounts in this forum. It will come up in the search results. There's a thread with lots of pics. I have it bookmarked but I'm on my phone and can't attach it.
Old 05-29-13, 10:47 AM
timmy0tool
timmy0tool's Avatar
i recall seeing a thread about it breaking. do you recommend removing the hose from the valve?
yes please get back to us on the link !
Old 05-29-13, 11:24 AM
Twista4004
Twista4004's Avatar
Originally Posted by timmy0tool
yes please get back to us on the link :d !
+1
Old 05-29-13, 12:45 PM
sha4000
sha4000's Avatar
Here you go. I'm in the process of getting mine done. I just did the tranny the other day and as soon as I get some more time I'm going to give the engine mounts a go. This is for a second gen with pics.
https://www.clublexus.com/forums/ls4...placement.html
There are no pics in this one but it's another way to go about it.
http://us.lexusownersclub.com/forums...ount/?hl=mount
This is for a 91 so should be the same and it has pics.
https://www.clublexus.com/forums/3445748-post5.html
Old 05-29-13, 02:19 PM
YoshiMan
YoshiMan's Avatar
The two things i know that are CRITICAL are unbolting the said heater valve, and also unbolt/unhook the power steering return hose where it connect to the fender.
The Heater valve can be unbolted and simply moved out of the way, i had no issues with it afterwards, just keep your eye on it so you don't crush it!
Since i was replacing the P/S pump at the same time, it was already unhooked, but if you look at it you will see that if you simply jack up the engine, you are going to snap the power steering return hose, or worse, damage the hard lines
Old 05-30-13, 05:07 AM
billydpowe
billydpowe's Avatar
yes if you can or just take it loose so it can move with the engine, just be careful of it. we have broke two of them...
Old 05-30-13, 06:07 AM
lhgdale
lhgdale's Avatar
Thanks for all the info!! Just to be clear the heater control valve is at the top of the firewall offset slightly to the passenger side?
Old 06-07-13, 06:45 AM
sha4000
sha4000's Avatar
Just changed all my mounts last weekend and now I seem to have more noticeable movement in the engine than I had with the old worn out mounts. Do the new mounts need time to settle since the engine is in a new position?
Old 06-07-13, 08:28 AM
Twista4004
Twista4004's Avatar
Excellent question. One (inexperienced person) would think that they would actually get softer after settling. This is a guess as I've never done this on a Lex. Funny though, I just did this with my dad's Chevy Venture this past Tuesday.
Old 06-07-13, 09:40 AM
Dranom
Dranom's Avatar
Ugh!! I need to replace mine soon also
Quick Reply: Ordering Motor Mounts, What Else Should I Replace
