1997 front rotor help please!
Can't get the front rotors of on my 97 LS. Could it be they are rusted on or are the screws in the rotors holding them on? They won't budge at all
yes you'll need to remove the two retaining screws first before you can try prying them off.
also they could still be rusted on. there is a threaded hole on the rotor where you can thread in a bolt to help push the rotor out. using PB blaster helps break the rust too. good luck!
