Can u see if EGR pipe's broken without taking it off (1st gen)?
Old 04-16-14, 08:46 PM
peterls
peterls's Avatar
Default Can u see if EGR pipe's broken without taking it off (1st gen)?
As the title says - is it possible to see that accordion part of the EGR pipe, I guess it must be on the bottom of the pipe, without taking it off first?
I guess, I would like to see first if it really needs replacing.
Some days I get smoked like a mosquito from all the exhaust coming in, and others - absolutely nothing. I don't get it. Maybe the opening in the pipe is moving somehow and sometimes the gasses get through, and sometimes they do not? I noticed it seems to smoke more on uneven roads...
Or is it possible that it is something else? I can't imagine the exhaust pipe being cracked since this car never left California and has barely seen rain, much less snow or salt.
Old 04-17-14, 12:50 AM
cgawelko
cgawelko's Avatar
Well from what I have read the Y pipe can blow out as well. I would try feeling with your hands (after letting the car sit for 8+ hours of course) on the accordion bit and if you feel a gap or split then its no good. If not I would look at the Y pipe piece as the next culprit if not just some flange gaskets.
Old 04-17-14, 09:52 AM
billydpowe
billydpowe's Avatar
something like this should work
Attached Thumbnails Can u see if EGR pipe's broken without taking it off (1st gen)?-mirrow.jpg
Old 04-18-14, 10:14 AM
peterls
peterls's Avatar
OK, thanks for suggestions. Would one of those snake like cameras from harbor freight help at all?
Old 04-18-14, 11:47 AM
timmy0tool
timmy0tool's Avatar
you can hear the leak more than see it. i've had my EGR pipe leaking for a few months now and there is no smoke that i can see but i do smell the gas outside the engine bay and can definitely hear it!
if you see actual smoke, i'm leaning towards your power steering burning off into the intake.
Old 04-18-14, 11:51 AM
peterls
peterls's Avatar
No visible smoke, and I can't tell if it sounds different, because it has been this way since i bought it. It may be just a small crack that opens and closes depending on weather or something...
blumagic
06-13-17 01:42 PM
2012IS250
Performance
08-21-14 12:49 PM
Diggzlex
07-02-12 04:56 AM
kate
12-02-05 08:12 PM
PES300
09-08-05 04:40 PM
Quick Reply: Can u see if EGR pipe's broken without taking it off (1st gen)?
