Knock Sensor
Knock Sensor
Anyone know where is the Knock Sensor (KS)is located in 1UZFE engine. My mechanic did s OBDI scan and told me that the KS bad that is why my Traction Control light and Check Engine light is on. Any pictures will be greatly appreciated. I will try to fix it myself. Thanks
Knock Sensors location: Under intake manifold, on top of cylinder block. Knock sensors are normally open. Measure the resistance between knock sensor connector terminal and knock sensor body ( hex portion), if there is continuity: replace the sensor.
Q Nguyen
Q Nguyen
