LS400 issues -missing under load
Old 10-25-13, 10:03 PM
LSVIP
LSVIP's Avatar
Default LS400 issues -missing under load
So I was driving today and out of nowhere, my engine began to sputter as I put it under load. This only progressed to stuttering at 1.5 rpm in first gear.
When I put it under load as it stutters, it throws a CEL for a quick second and it's gone again. I got a new ECU a few months ago, so I don't believe it's a capacitor as well as the fuel pump.
I was wondering if anyone had opinions?
I'm between spark plugs, coils and fuel air sensor.
Old 10-25-13, 10:13 PM
RA40
Super Moderator
RA40's Avatar
Year of LS and how many miles? Cowboy is going to ask if you are sure the ECU was repaired correctly with the right caps being used. And we'll want a code so we know what it exactly is if it is readable.
Old 10-25-13, 10:36 PM
Yamae
Forum Moderator
Yamae's Avatar
Is that really a new expensive ECU shipped from Denso?
Why don't you take photos of the ECU board and show us?
Old 10-25-13, 11:13 PM
LScowboyLS
LScowboyLS's Avatar
I think you mean that your ECU is new to you, not actually new.
but even if it is "new" to you or really new old stock, it still has very old capacitors that have a design defect and need to be replaced
PS - Florida is the most common state for ECU capacitor issues!
Old 10-25-13, 11:29 PM
LSVIP
LSVIP's Avatar
Originally Posted by LScowboyLS
I think you mean that your ECU is new to you, not actually new. but even if it is "new" to you or really new old stock, it still has very old capacitors that have a design defect and need to be replaced
Well, in this case, I paid 800 dollars to replace my ECU
Old 10-25-13, 11:33 PM
LScowboyLS
LScowboyLS's Avatar
Please tell us the year of your LS and where you purchased the ECU and what codes does a scan give?
Old 10-25-13, 11:51 PM
LSVIP
LSVIP's Avatar
1993, Dealership, and my buddy is gonna flash it tomorrow to see what codes it throws
Old 10-26-13, 02:16 AM
Yamae
Forum Moderator
Yamae's Avatar
Don't flush it. Just read the code(s).
Old 10-26-13, 12:38 PM
Gene01
Gene01's Avatar
Freudian slip ? :-) :-) (couldn't resist)
Old 10-26-13, 12:56 PM
usoff89
usoff89's Avatar
You can read the codes yourself, its very easy!
Here is a link explaining how to do it....
http://www.lexls.com/tutorials/intro/codereading.html
Old 10-26-13, 02:55 PM
fsuguy
fsuguy's Avatar
Possible bad ignition coil - before blaming the ECU, check the coil/s. What you are describing sounds very much like a coil having given up its ghost!!! Start up the car, run the engine and look under to see if your cats look like they are in hell - they will glow cherry red from unburned fuel combusting in the cats!!! Alternatively check for spark!
Old 10-26-13, 03:50 PM
python
python's Avatar
why did u replace ur ecu?
Old 10-27-13, 08:25 PM
LSVIP
LSVIP's Avatar
Thank you! I'll have to have a look at it when I have time to jack it up! I think it may be the ignition coils or spark plugs. I pulled the covers off and found one that was very corroded
Old 10-27-13, 08:26 PM
LSVIP
LSVIP's Avatar
My grandparents (who I received the car from) wouldn't let me work on it when it was having issues the first time. The guy they took it to thought it was a capacitor in the ECU and instead of welding in a new one, bought a new ECU. The issue was the fuel pump after all was said and done and I was pissed.
Old 10-27-13, 08:44 PM
LScowboyLS
LScowboyLS's Avatar
well sorry to hear that the new ECU is not doing the trick, but if your other ideas don't work, could you please pull the ECU and photograph the inside a let's have a look?
because first of all, the ECU isn't new, those are over $2000, and new or not, the capacitors are still very old, and this is a well known problem on '93 models
engineer Yamae from Japan has a ripple test you can do to check the condition of the capacitors, and the visual check is easy enough and often there is a huge mess inside!
here is the '93 factory service manual, that should help a lot!
Quick Reply: LS400 issues -missing under load
