transmission question
Old 06-02-13, 05:09 PM
ef9racer
ef9racer's Avatar
Default transmission question
My tranny went out in my 90 ls400 but i do have a a341e from a mx83 can i change the bell to make it work.
btw i do know the gearing difference in the two.
Old 06-02-13, 08:12 PM
LScowboyLS
LScowboyLS's Avatar
the A341E you have will work fine, except for the ECU, which controls the transmission in the LS400, it is gonna be a bit confused, I am afraid, also I suspect the shift solenoids would be a bit different, though very similar, but you have a decent shot they are identical.
what year is the MX83? - do you know the history of this particular tranny, is it in good shape? - the filter screen will tell you a lot.
I think if the main electrical connector is the same (likely), you have a decent shot, if the output shaft is the same - the speed sensor is the only other potential issue I see. - The ECU won't like it at first, but it will learn and eventually be happy.
Old 06-04-13, 01:18 PM
ef9racer
ef9racer's Avatar
its a rebuilt transmission with less than 1000 miles on it. and it is also from ether a 89 or 90 cressida.
Old 06-04-13, 05:47 PM
LScowboyLS
LScowboyLS's Avatar
● check the physical compatibility of the main electrical connector
● check the size of the output shaft
● compare the Toyota part numbers of the solenoids between those years of Cressida and your year of LS400 - you can do this online at www.toyotapartszone.com and at lexus.sewellparts.com
● disconnect negative battery cable for a few hours to fully reset ECU
then I think you have a pretty good shot if the above items check out, because you will really just be down to the speed sensor as about the last potential "gotcha"
Old 06-05-13, 06:50 PM
ef9racer
ef9racer's Avatar
sometimes i wish that lexus was like hondas. in the aspects that they are like legos and so easy a caveman can build them. lol
Peli
08-01-17 01:19 AM
Ltaboso
IS F (2008-2014)
04-22-15 11:44 AM
ls400geek
02-06-13 03:02 PM
LexGX
06-16-10 01:20 PM
Quick Reply: transmission question
