Size matters! - let's put a BIG oil filter on our LS!
Old 07-04-13, 02:28 PM
  #91
LScowboyLS
LScowboyLS's Avatar
an oil filter is technically compatible and legal for liability reasons, if the following things are true:
● same thread size
● same gasket diameter
● same bypass valve relief psi
● no physical issues (hot exhaust nearby, sway bar in the way, ground clearance reduced, etc.)
Old 07-04-13, 02:30 PM
  #92
LScowboyLS
LScowboyLS's Avatar
Originally Posted by RA40
I had a few cuts of 1x12" so I stacked them. I won't be bale to get under the car but this is enough to be able to reach in for oil and tranny fluid servicing.
a stack of 1 x 12" or 2 x12" is even safer than jackstands!
Old 07-04-13, 04:23 PM
  #93
python
python's Avatar
what about micron rating..what about the fact that ur oil doesn't even go through ur filter once ur rpms reach a certain level? btw u looking for personal validation?
http://www.bobistheoilguy.com/forums...3020171&page=1
http://www.bobistheoilguy.com/forums...89#Post3005589
Old 08-29-13, 04:12 AM
  #94
LScowboyLS
LScowboyLS's Avatar
Originally Posted by Kansas
Yes, poorly designed, poorly fitting aftermarket oil filters can harm your engine. There are no demonstrated benefits to doing this mod - only the usual "urban myths".
there are NO poorly fitting nor poorly designed oil filters in my list of recommended filters in post #1, these oversize oil filters listed (including the original 90915-20004 that came on your car from the factory) are the finest filters in the world, and have been carefully matched for gasket diameter, thread size and pitch, as well as bypass valve release pressure.
Oversize filters do have some benefits, such as much higher capacity, for folks who tend to let their change interval slide occasionally, which is not a problem if the owner is using a top quality full synthetic oil that is easily good for 10-15k miles. We are all human, and screw up sometimes and don't get the oil changed on time. This is extra insurance.
There have also been some advancements in anti-drainback valve (ADBV) technology over the years, the Motorcraft FL-400s, for example, has quieted startup noise on some engines that were noisy with all other filters. - This is because Ford had some issues with this and went a little overboard designing a super filter with a remarkable ADBV to hide a bigger engine design issue, but we are the beneficiaries!
The "running cooler" is a myth however, and overall oil cleanliness improvement between changes is marginal at best.
Old 09-02-13, 10:57 AM
  #95
peterls
peterls's Avatar
Here is something I have not been able to find an answer for:
Ideally, we want our filters to filter out as much as possible ,down to the minutest little particle. But in doing so, the filter is bound to become clogged sooner. Also, it means its filtering element is finer, needing higher pressure to push the oil through.
So there is that balance that needs to be met: filter as much as possible while allowing oil through.
And my question is: does 1UZ-FE oil pump produce enough oil pressure that one can use filters which filter out even the smallest particles? Or would using such filters only clog up the filter quickly and result in no filtering very soon as there is not enough pressure any more and too much resistance in the filter?
Old 09-02-13, 12:42 PM
  #96
LScowboyLS
LScowboyLS's Avatar
Not exactly, it is the "medium size" particles which damage bearing clearances, and other critical areas
very small particles can fit multiple particles into a small clearance and they act like ball bearings and spin on each other, doing little if any damage
large particles are too large to fit into critical areas
the size of this damaging medium size particle will vary based on the engine, 1970's engines had large clearances, a 2014 engine has much smaller clearances, LS400 is somewhere in the middle of these two, on the smaller side
the oil pump of the LS400 and any of the filters I mentioned in post #1 of this thread are a good match and will catch these damaging particles
Old 09-02-13, 02:15 PM
  #97
Dutchy
Dutchy's Avatar
I really don't see the benefit in this. If you want to drive longer without an oil change i whould only change the filter then for a ORIGINAL one. So change the filter twice between oil changes. I just change the oil (mobil 0w40) every year with a nipparts oil filter (made in japan)
Cowboy, you recommend for everything OEM parts why not in this ?
Old 09-02-13, 02:56 PM
  #98
Lavrishevo
Lavrishevo's Avatar
Advances in technology. Plus it's hard to get the Nippon / Denso (90915-20004) oversized filter in the U.S. The current OEM filter ain't what what it used to be...
Old 09-02-13, 05:24 PM
  #99
peterls
peterls's Avatar
is 90915-20004 even made any more? My understanding is that they stopped making it years ago (like 2004 or so), and whatever we find here is just old stock which would mean that eventually they will disappear and not be available anywhere... but maybe I am mistaken?
Old 09-02-13, 05:54 PM
  #100
LScowboyLS
LScowboyLS's Avatar
the Motorcraft FL-400s is rather over-engineered as a fix to a noisy engine on startup problem that Ford had, with the most advanced anti-drainback valve in any filter, so we all benefit from Ford's screw-up, and it is even economically priced!
Yamae would be the best person to tell us whether this original equipment filter that came installed on our LS's is still being made.
For what it is worth, it is one of the most free-flowing of all current filters that will fit the
1UZ/3UZ engines, and considerably larger than the current replacement filter sold by the dealership which is made in Thailand
Old 09-02-13, 08:01 PM
  #101
Yamae
Forum Moderator
Yamae's Avatar
I make it a rule to use genuine oil filters and I don't have any particular interest on non-OEM filters.
Below is what I was informed by a local dealer when 90915-20002 was not available any more.
90915-20002 for Celsior UCF10,11,20,21
90915-20004 for Celsior UCF30,31
90915-20002 is not manufactured any more and the dealer uses 90915-20004 instead of 90915-20002. According to them, 90915-20002 was replaced to 90915-20004.
So 90915-20004 is widely available here in Japan now.
Old 09-03-13, 08:45 AM
  #102
peterls
peterls's Avatar
Which makes me even more frustrated that it is so hard to find here - the 90915-20004.
Can we organize some sort of a group purchase or something, from a reliable source? I found that one site, and it seems legit, if we disregard the problem in their HTML code which is showing some irrelevant stuff such as Polo t-shirt offer... but other than that, any other ways to get a hold of this OEM fitler?
Old 09-03-13, 10:55 AM
  #103
RA40
Super Moderator
RA40's Avatar
That 90915-20004 filter shows up now and then, considering the cost, there are others that suit the need. If I didn't have the 20004, I'd use the current one as recommended by Lexus and this is suitable for the 5-7K intervals.
Old 09-03-13, 11:28 AM
  #104
johnnyg66
johnnyg66's Avatar
Here...
http://www.l-tunedparts.com/product/?id=2217
Old 09-03-13, 05:55 PM
  #105
peterls
peterls's Avatar
Originally Posted by johnnyg66
Yup, that's the one I found too. Notice the "Ralph Lauren Polo" links - don't know what to think about that... its probably legit, but would like to hear from someone who actually bought one there recently... And they seem to sell only a case of 10.
Quick Reply: Size matters! - let's put a BIG oil filter on our LS!
