ls400 EZ Coilovers what Damper ??
Old 04-18-13, 11:28 AM
timmy0tool
timmy0tool's Avatar
the coilovers already come with preload out of the box. if you want to go stiffer w/o adjusting the damping what you do is you increase the preload. it is essentially compressing the spring further which equals more tension and stiffness.
what you do is you bring the collar, located directly below the spring, upwards to compress. it will be difficult to spin due to the tension already there, and bringing it up will add even more tension. there is a better way to adjust the preload but that requires the coilover to be out of the car and taken apart.
Old 04-22-13, 07:15 AM
Hiroshi12
Hiroshi12's Avatar
I see. So, damping equates to ride comfort and not height? Then how do you adjust the height? Is that also "set" out of the box? Sorry, but never had coils before.
Old 04-22-13, 07:45 AM
SynicalVip
SynicalVip's Avatar
To adjust height you do that with the bottom ring collar. Move the bottom collar up will lower your car, the first two collar where the coil sit on that's where you set your preload.
Old 04-23-13, 01:41 PM
looneytune
looneytune's Avatar
Let me know what you think about this set up. Was looking at the same set yesterday.
Old 04-29-13, 11:35 AM
looneytune
looneytune's Avatar
Any updates?
Timbo1j
Suspension and Brakes
23
06-28-14 05:56 PM
94Soarer
05-29-13 01:46 PM
stas2007
07-06-12 10:09 AM
RobzKar
10-11-11 10:10 AM
J-Aristo
10-14-10 10:56 AM
Quick Reply: ls400 EZ Coilovers what Damper ??
