1-LS: need help with wheel & tire fitment
Old 03-01-13, 07:30 AM
TaffyK20si
TaffyK20si's Avatar
Originally Posted by PureDrifter
just a reminder, 1st gen and 2nd gen have very different clearances so fitments cannot be compared across them.
'95-00 generally can run more aggressive than '89-94.
My bad... :/ I didn't even think about him having a 1st gen. All I really paid attention to was the work varianza's.
Old 03-01-13, 08:25 AM
makoa3
makoa3's Avatar
Originally Posted by Dranom
You can fit around 18x9 +25-35 R disk, 18x10 +25-30 O disk to give you so what of a lip
cool thanks, i'll check that out
Old 03-01-13, 10:37 AM
RA40
Super Moderator
RA40's Avatar
Guys tell him what size and brand tires you are running with these wheels. makoa3, if you don't want these mild stretches and a more typical tire size (minimal stretch), back off 10-20mm offset so that you can have fender clearance. Stretching will alter that based on sidewall. More stretch, you'll be able to get a bit lower offset.
This is a conservative fitment suggested from VIP Style. You can go either way depending on tire sidewall characteristics.
Attached Thumbnails 1-LS: need help with wheel & tire fitment-vpstywhl.jpg
Old 03-01-13, 10:55 AM
TaffyK20si
TaffyK20si's Avatar
97 2nd gen LS:
I'm running a 225/35/19 on 19x9+9 w/2mm spacer and 245/35/19 on 19x10+13.
Old 03-01-13, 01:03 PM
makoa3
makoa3's Avatar
that's good to know actually, i never factored in tires yet.. thanks
Old 03-02-13, 10:27 AM
radiokilla
radiokilla's Avatar
18x10 +17 18x10.5+16
-3 Camber front -6 Camber Rear
Old 03-03-13, 05:52 PM
makoa3
makoa3's Avatar
can anyone help me with tires?
i'm getting 20x8.5 front
rear 20x9.5
Old 03-03-13, 05:55 PM
makoa3
makoa3's Avatar
Default need recommendation on tires
getting new rims, don't know what size tires to get mainly, and if anyone wants to recommend a brand too, cool too..
rear 20x9.5
thanks everyone
Old 03-03-13, 06:02 PM
Joshcar
Joshcar's Avatar
All depends what you're going for if you want something really grippy, something really comfortable, or something that will stretch well. Do you wanna go stance or DD?
Old 03-03-13, 08:58 PM
RA40
Super Moderator
RA40's Avatar
What characteristics do you want in a tire?
Long tread wear, grip, noise, price...
Old 03-04-13, 08:19 AM
makoa3
makoa3's Avatar
thanks guys got i it figured out to get i asked the seller what tires i should get. he explained the differences in everything..
front: 20x8.5 +35 245x35x20 tires
rear: 20x9.5 +40 255x35x20 tires
thank you all for your input
Old 03-04-13, 09:28 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
uhh those are on the big side for your chassis, hope you don't plan on going too low. that's a massively meaty setup for a 1LS.
jcsulli480
01-14-16 09:15 AM
idoke1
IS F (2008-2014)
12-22-15 10:53 PM
luvmylex1
08-17-14 11:37 AM
Rogue720
55
05-14-14 11:27 AM
S2dannyKeo
03-05-13 11:19 AM
Quick Reply: 1-LS: need help with wheel & tire fitment
