96 timing belt mark help
Old 01-24-13, 11:49 AM
davids2k
Registered User
davids2k's Avatar
Default 96 timing belt mark help
hi i need help with the timing belt mark but there isnt any on the driver side
and also which way the belt should face? right and left on the belt
Old 01-24-13, 12:28 PM
steve2006
steve2006's Avatar
It looks to me that the timing indentation mark on the right cam pulley is at the bottom which is way out.
This may help
http://www.lexls.com/tutorials/engine/timingbelt.html
As for the belt direction it should have a direction arrow on it indicating the which way it should be fitted ( normal engine rotation direction) and also timing marks on it which should line up to both cam pulleys and the crank pully.
A bit late now but it is a good idea to mark the timing points with correction fluid before removing the belt.
Old 01-24-13, 01:03 PM
davids2k
Registered User
davids2k's Avatar
there is no timing indentation mark i checked all around
Old 01-24-13, 01:25 PM
LScowboyLS
LScowboyLS's Avatar
well you still have that ring thing belt guide attached to that pulley so we can't see
are you sure these are both the real OEM pulleys? - they should be identical and they are not
also, the marks on the timing belt are a help in verifying the installation, but they really are of no consequence, the car doesn't care
PS - why are the valve covers off?
would be a great time to replace the spark plug hole seals!
Old 01-24-13, 02:16 PM
davids2k
Registered User
davids2k's Avatar
the valve covers were off because the idiot that did my timing belt before did it wrong and it got bent valves.
yeah they are OEM pulleys. i dont think it been replaced before.
Old 01-24-13, 03:27 PM
LScowboyLS
LScowboyLS's Avatar
then the cam pulleys need to be verified that they are installed correctly, and also the crank pulley must be verified the same way (i.e. you need to verify that the TDC mark on the crank when at the 0 timing mark really is at TDC by inspecting cylinder #1
Old 01-24-13, 03:42 PM
timmy0tool
timmy0tool's Avatar
Originally Posted by LScowboyLS
I still want to know why one cam pulley has an outside belt guide and one does not
this is a stock design.
here is how my gears lined up when i did my tbelt on my 97. you need to have the front valve covers to show the markings if i'm not mistaken.
Old 01-24-13, 03:59 PM
LScowboyLS
LScowboyLS's Avatar
yeah, I never even noticed the pulleys are made different before - weird
that still doesn't explain the lack of a mark on his driver's side pulley, or is that the mark on the bottom of the pulley in the pic, hard to tell
Old 01-24-13, 04:15 PM
timmy0tool
timmy0tool's Avatar
mark is at the edge of the pulley like a little hash mark or grooving. check the back of the pulley as well.
Old 01-24-13, 08:29 PM
LScowboyLS
LScowboyLS's Avatar
ok, glad you found it!
Old 01-25-13, 12:27 AM
davids2k
Registered User
davids2k's Avatar
^ thats a dent!
i found it, i had to take the cam out, it was in the back, made a tiny mark in front to match up the back so i know where it is
erock202
Performance & Maintenance
02-09-15 02:00 AM
Sololock
26
05-30-12 08:56 AM
Vadim540i
SC- 1st Gen (1992-2000)
11-28-10 11:42 AM
sillyboi12
01-11-10 06:57 PM
rx7guy
04-29-09 12:27 PM
Quick Reply: 96 timing belt mark help
