My adventure to Function/Form!
#33
from the looks of it, they will fit the UAS bags but this is not certain. there really isn't a "kit" UAS produces, it's just brackets custom made to order. when i told them i have coilovers they just copied the megan specs and gave me the brackets. being the coilovers are fully height adjustable, the brackets should work on any coilover set. they also make brackets for stock shocks if you so desire.
#34
Like Timmy said, there isnt a "kit" thats why they are called Universal Air Suspension. They will work with these coils with no problem, just like any coil over. From what I was informed, there will be a colabo with UAS and F2. So keep a look out.
#37
Sorry for not updating this, Thanks for reminding me JPratt! Ok so here the updated, after talking to the guys at F2 and hearing what you guys want to see, I was able to get both ideas together and make it happen. As you guys know, the front where 14K and the rear was I believe 8K. I went ahead and ask for a 10K for the rear just to make sure it was able to hold items and what not. Gave the idea to F2 and they made it happen! Within a few weeks i got a call from them saying it was in. I was super surprise that it was really quick! Customer service is top notch down there and not only is the service great, but the really hear you out on what is needed or what could be improve to your liking. Anyways went down to the headquarters and got the springs installed. AND WOW! Rides a lot better not to harsh but just right. Gave it a few weeks to break in and i took the bold move to go a tad bit lower in the rear and to a ride with almost a few car! I had 3 people in my car and not a sound out of it. I also didnt bottom out! and im talking about adults not kids. Over all im very impress with the out come of these coils. WIth that 14 and 10 k Ride is amazing for being low. Slightly stiffer from factory lets just put it like that.
I will do a shoot soon with the new drop. Ive been moving and its a pain in the butt. Also keep your eye out, the kit will be here any day now!
#39
Cool, nice update!!! So will 14k/10k be the standard they sell now? And I've seen some of these on eBay. Are these the same ones you're running? Or are these a new prototype they're working on? I might be making the leap into buying some suspension. Just trying to decide what I want to go with. How would you compare these to the Megan's now after owning them for awhile?
#40
Im not 100% sure if it will be release with 14/10k. These are the only set for the 98 ls. Im pretty sure F2 hasn't release them if there not listened on there site. So dont jump on a set from ebay if anything, if your really want a set please pm me for more info and ill talk to F2 and so on. But to compare these to my megans... Lets just say ill never look back. Honestly I am blown away with these coils.
#41
Nice!!! Here's the eBay ones I was talking about http://www.ebay.com/itm/130834066785?redirect=mobile
#44
Yeah they come with 14/10k springs. Very nice ride with that setting.
WOW! 18/14K DAMNNN!!! You got ***** man! hahahah.
#45
Here the run down guys.
Function & Form Type 2 for LS400
APPLICATIONS:
LEXUS LS400 1998-2000
Message me for other questions
Spring Rate: Front-14Kg Rear-10Kg
MSRP $1,000.00
The Type Two Coil-Over is our flagship full bodied coil-over. More aggressive than the Type One, we aimed to make it the ultimate street inspired coil-over. Our philosphy was a coil-over designer for street durability, comfort, and style, but can endure the occasional track days. A lot of our customers dream of hitting the track, but the reality is they Twant to enjoy their pride and joy on the streets as well. A dedicated track car is not a choice for many. But thats ok, because we designed a suspension that can let you enjoy the streets or an occasional fling on the track. You pick.
In achieving this, we wanted to make a stronger product to endure the imperfections of the real world. Steel materials have been used for the lower mounts to give the shocks OEM durability. Spring rates are slightly more aggressive than a Type One, to handle occasional track duties and spirited street driving (we always suggest safe and smart driving on public roads). But this did not sacrifice ride quality. Twin tube shocks are used for durability and a smoother ride on the street. Our goal is to offer you a suspension that can handle the wear and tear of daily driving duties. With the Type Two’s 32 levels of dampening adjustment, you can dial in ride and handling characteristics for the street or the track, giving you ultimate versatility.
Dampening adjustments made with a **** that “clicks” at each level
Steel lower mounts for maximum strength
Adjustable Camber Plates *when applicable*
Top mounts included on applications that are applicable
Ride height adjustable seperate of pre-load
Special oil lubrication to withstand conditions from -40 degrees Celsius to 200 degrees Celsius.
Dual tube shock design for maximum ride comfort.
Double wishbone piston size 43mm
McPherson strut piston size 50mm.
-Function Form
APPLICATIONS:
MSRP $1,000.00
-Function Form
