90 ls400 diff question
10-29-12, 07:33 PM
first off i did searched but found nothing useful
my question is what diffs are interchangable for the 90 ls400 cause i found a 96 ls400 at a local u-pull-it.
10-29-12, 08:07 PM
BahHumBug
the internals are interchangeable, the cases are not.
'89-94, 95-97, and 98-00 all had different diffs and mounting configurations.
11-01-12, 10:25 AM
do any of those have an lsd?
11-01-12, 12:34 PM
BahHumBug
Quote:
Originally Posted by
TheGerman
no, no lexus ever came with an LSD before the 2001/2002 IS300.
as it's unrelated to this thread, i suggest you search the LS400 forum for "LSD*" without the quotes but with the star for more information.
11-01-12, 08:45 PM
NELOC Mod
Direct bolt in,, no problems - 89-94. As Puredrifter stated,, the internals with the different years are all the same, however the case sizes are different.
11-02-12, 07:33 AM
Thanks for the info cause when I dropped my rearend it had a salvage yard tag of 1998 ls400.
11-02-12, 02:45 PM
BahHumBug
if you're still running the '96 rear subframe then it was a tagging error as the '98-00 rear end won't bolt in.
plus you would see a performance loss as the ratio is taller in the '98-00.
KalimaD
GS - 1st Gen (1993-1997)
11-20-13 05:21 PM
hjcaywood
12-18-08 10:12 PM
dwa
17
11-14-08 03:46 AM
bzebern
08-14-08 02:51 PM
recoil
Performance & Maintenance
07-07-08 08:38 PM
