Hazards work......turn signals don't!!
Old 10-14-12, 01:11 PM
Kanderson1
Kanderson1's Avatar
Default Hazards work......turn signals don't!!
Forum...changed all the fuses under dash & under hood, however
my turn signals do not work. Hazards work fine...but no turn signals. I already purchased a flasher relay, but i haven't replaced it yet. Any suggestions before i change the relay?
Old 10-14-12, 04:51 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
its probably not the flasher relay if the hazards work iirc, it's more likely to be the switch itself or clockspring.
Old 10-15-12, 08:32 PM
Glidin316
Glidin316's Avatar
what year?? have u checked the trunk wire harness? or the Lamp failure module? any burnt solder points/connections. etc.
Old 10-16-12, 02:15 AM
Kanderson1
Kanderson1's Avatar
1995....funny thing, they were working fine until I changed the tail lights and turn signal light housing all the way around. I didn't have to rewire or change any bulbs.
Old 10-16-12, 10:53 AM
cobalt91
cobalt91's Avatar
Probly might want to check the connecters in the tail lights then.
Old 10-16-12, 11:26 AM
timmy0tool
timmy0tool's Avatar
did you replace the tails with LED? what did you do different? work backwards from when it was working.
Old 10-16-12, 07:25 PM
Kanderson1
Kanderson1's Avatar
Im gonna take some time this weekend and
check
Old 10-22-12, 01:37 AM
Kanderson1
Kanderson1's Avatar
I pull the starter relay.the contacts with dirty. I clean them and the car starts fine now
LexusJen13
IS - 1st Gen (2001-2005)
07-30-16 08:02 AM
14blk250a
12-07-14 05:50 PM
MJames23
04-09-12 11:49 AM
Blizzy
SC- 1st Gen (1992-2000)
15
08-08-07 07:56 AM
sc400atl
Maintenance
04-25-04 12:36 PM
Quick Reply: Hazards work......turn signals don't!!
