All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
Old 01-19-15, 01:08 AM
  #1066
Ryan2015
Ryan2015's Avatar
Why won't it let me view the last page
Old 01-19-15, 07:58 AM
  #1067
Unclebob9
Unclebob9's Avatar
Originally Posted by KawiLex
Yamae, thanks for responding..
I will say this.. I replaced the caps and everything ran very smoothly. No throttle issues, or shifting issues, or speedo issues. I decided to keep the car after replacing the caps..(it's a friends car)... and drive it for a week to make sure it was good. The car ran excellent and powerfully.. I gave it back yesterday night... then first thing this morning she reported that it was running rough and was lunging when she gave it throttle. She limped it home and then couldn't get it to start!
I ran an entire tank of gas through it in the week I had it and had ZERO problems.
Things to note:
- I kept it outside in the freezing weather while I had it. She parked it in the warm garage when she got it back.. Clearly that shouldn't be an issue.. but you never know.
- Before I took the car and replaced the capacitors, she replaced the battery.
- Supposedly a mechanic tested the fuel pump and found no issue, but the car stopped acting funny while he was in possession. Sound like pump issues? Maybe TPS? Timing?
Basically, it seems that replacing the capacitors didn't fix the issue.. though it may have fixed some other things that didn't keep the car from running.
I am completely amazed I had it for a week, ran a full tank through it and found no problem.. the car ran great, always started strong and ran strong, then she gets it and it's not working!
I found the following thread, but want to know what you think!! This LS has multiple mechanics and 3 of my tech friends rather confused..
https://www.clublexus.com/forums/ls4...ml#post8263261
when this happened to me, it was because I had a capacitor in backwards.
Old 01-22-15, 08:39 AM
  #1068
Arigato1
Arigato1's Avatar
Hi LScowbowLS , I have a 1993 SC400 and i need to replace the capacitors but I don't know witch ones and how many , would you please tell me ? Help!
Thanks
Old 01-22-15, 08:53 AM
  #1069
Arigato1
Arigato1's Avatar
Default 93 SC400 ECU capacitors
Originally Posted by Yamae
Toyota has started to use Nichicon's electrolytic capacitors that containing “quaternary ammonium salt / compounds" in the late 80s and has kept using them for a bit more than a decade. The reason why they used those capacitors was simply because the internal impedance was low enough and showed good performance in removing noise and ripples at DC lines.
A little before that many electronics industries in Japan started to use similar capacitors that were for non automobile use and faced serious leaking problems in the early 90s. The details are written below but all in Japanese.
http://ednjapan.com/edn/articles/1208/01/news006.html
I don't have the time nor the ability to translate all the contents so I will just translate the title.
“80年代末期の“亡霊”に注意” or “Watch out for the “phantom” in the late 80s”
The “phantom” here means the electrolytic capacitor which contains infamous “quaternary ammonium salt / compounds". Judging from the title, it is dangerous to use this type of capacitor without taking any special precautionary countermeasures.
Most of the electronics companies in Japan stopped using this type of capacitor in the early 90s or mid 90s for fear of leaking problems. But many automobile industries kept using them because they needed good performance. Another reason was that they have been used in high reliability type-capacitors. Nichicon has been manufacturing special versions of this type for the automobile industries using specially coated lead wires with special sealing rubbers. One of my colleagues evaluated them and found the automobile type much better than those types designed for home appliances applications but the lifespan was not as long as those electrolytic capacitors that use regular liquids. Also the high reliability types were very expensive. I cannot show you the details of the evaluation results but what I can say is that the lifespan is longer than roughly 10 years or so but you cannot expect a lot if used for longer than that.
As I fix different ECUs as a volunteer, I came across many failed Nichicon's PF(M) type capacitors these days, some 12 years old, some 15 years old. What I can say now is that my colleague has done a good job evaluating the capacitors using an oven in the accelerated mode. In accordance with that and from my own actual experience, ECUs older than 12 years are ready to fail someday soon or later, that I can say with confidence.
Below is a failed capacitor used in a 97 Celsior. You can see how the leg has corroded and the part on the board where liquid has leaked out.
Those who want to replace Nichicon's type PF(M) capacitors to avoid future problems, be sure to use low ESR type capacitors. Never select capacitors just seeing the voltage and the capacitance. I recommend you to use Rubycon's type ZLH or Nippon Chemicon's type KZH. These do not contain infamous "quaternary ammonium compounds" but their ESR is low enough. You also have to pay good attentions against electric static discharge when doing the replacing job. A wrist strap is definitely needed to use. Without it you might damage the ECU.
Regarding capacitors Rubycon's type ZLH and Nippon Chemicon's type KZH, the availability in USA is not so good. LScowboyLS was kind enough to try to find capacitors that were OK to use and he listed up at the post #1. Those capacitors are good enough.
Hi, I have a 93 Lexus SC400 and I dont know how many and witch capacitors should I replace , I need help Thank you
Old 01-22-15, 08:55 AM
  #1070
Arigato1
Arigato1's Avatar
Default Help
Originally Posted by LScowboyLS
*photo courtesy of distinguished Japanese ECU engineer Yamae
IMPORTANT: The capacitors may look perfectly fine and yet be bad, they look great at first, then deteriorate and cause damage to the ECU very quickly
MODELS/ENGINES AFFECTED:
This issue affects all Lexus & Toyota models with the following engines: 1JZ, 2JZ, 1KZ, 1UZ, 5E, 1G, 3S
The following are some of the models affected:
● Lexus LS400 - 1990-2000 (in 1997 and earlier models, the problem is extremely common)
● Lexus SC300 - 1993-2000
● Lexus SC400 - 1992-2000
● Lexus GS300 - 1993-1996
● Toyota Celica GT - 1985 -1998
● Toyota Supra Mark III (JDM) - 1986-1993
● Toyota Supra GT - 1995-1997
● Toyota Supra Mark IV - 1993-2002
● Toyota Supra Twin Turbo - 1993-2002
● Toyota MR2 - 1990-1999
● Toyota Camry - 1987-2001
● Toyota Soarer - 1992-2000
● Toyota Aristo - 1993-1996
● Toyota Celsior - 1990-2000
SYMPTOMS:
Please understand that any one of these symptoms can be a sign of ECU capacitors beginning to fail. - You do not need all or most of them to have this issue!
Your ECU capacitors are strongly suspected if you have at least one of the following intermittent issues on your Lexus or Toyota:
● problems in getting into diagnostic mode or scanner says "no communication"
● random dropping into "limp home" mode
● weird shifting problems
OBD port is unresponsive, seems dead
● throwing random fault codes
● engine won't rev out/rev limits at 2000 or less rpm
● engine runs like crap, then suddenly runs fine again
● random not starting or cutting out
● low idle or erratic idle
● often very hard to start, requires starting fluid
transmission will not automatically shift, only manual shift is possible
● transmission jerks from 1st to 2nd gear, and kinda slips from 2nd to 3rd
● no A/C compressor operation
idle speed rolling up and down, or sometimes too low and sometimes too high
● speedometer not working reliably
● speed (cruise) control not working
● tachometer not working sometimes
● air bag light flickering intermittently
● A/C going into reset with flashing front defog light (front defog light typically flashing 10 times)
● check engine light on sometimes, but no codes stored, often in concert with ECT light
ECU not communicating with scanners or not displaying codes with jumper installed
● bad sulfur exhaust smell in concert with not running right above
I was actually experiencing several of these symptoms including ECU not wanting to communicate!
So, with no engine diagnostic codes to work with, I checked all of the grounds, voltages and other obvious causes, and then in a MacGyver-Steve Jobs moment of insight, I decided it must be the electrolytic capacitors inside the ECU, which had appeared fine in an earlier inspection a few months earlier when the problems began. I suspected it was the capacitors because I discovered this problem back in the 1990's on Nissan 300ZX and the Mitsubishi DSM models. History just keeps repeating itself! - It was also bound to be ECU-related, because this diverse set of issues has only on thing in common - the ECU!
sure enough, upon re-inspection, the corrosive leakage was very bad, so bad that the main circuit board could barely be saved!, I replaced all 6 electrolytic capacitors, and now every single problem listed above is gone! - and the engine also seems to have more low end power than it had even before the symptoms above appeared!
if you recognize ANY of these symptoms listed above, bad ECU capacitors are a likely culprit!
I now believe any Lexus over 12 years old would greatly benefit from having ALL 6, 8, or 10 electrolytic capacitors in the ECU replaced with high quality new ones! - these were not part of a defective batch, but rather a quaternary ammonium salt capacitor issue, as explained by world-renowned ECU engineer Yamae in post #8 below. (we are very lucky to have him here at Club Lexus!)
this is NOT something a junkyard computer would solve, it is an age and sitting up problem, a junkyard ECU would have the same issues.
IMPORTANT: It is critical that you use the exact premium Japanese low ESR capacitors I have linked to below in the recommended capacitors section, even if you are having someone else do the work, the correct capacitors are very rare type and they will not have them locally - if they use other capacitors, the repair will not solve the problems you are having!
the power difference alone makes it worth doing, and just because an electrolytic capacitor looks good, doesn't mean it is - 93-97 LS models are showing up with this capacitor issue in particularly high numbers and other models such as SC model are showing up in high number on even earlier years such as 1992, this also affects the 2JZ and other Toyota engines!
LET'S FIX IT!!
a new ECU would also solve the problem, those cost $2400 at the dealership, the parts I used to make mine just like a new one are less than $20 delivered from Digi-Key - and it is important to order from an authorized dealer of these great capacitor brands in order to avoid counterfeits - so FORGET EBAY, AMAZON, ETC.
make sure you use 105C rated low ESR caps from the 4 reputable Japanese capacitor companies Rubycon, Nippon Chemi-con, Panasonic & Nichicon
it is CRITICAL that the replacement caps be low ESR type and from one of the brands listed above - don't cheap out on your vital ECU!
WARNING - DANGER: this is not a good first-time soldering project, the existing capacitor removal and associated desoldering, cleaning, inspection, soldering and re-inspection is involved and is in some very tight places, you must be experienced at soldering and pretty good at it, or else you need to locate someone who is very experienced at soldering, and then you should buy the special capacitors this job requires, and then let him or her do the operation of replacing them - the NipponDenso ECU in your LS400 is a delicate piece of very expensive electronics. If you wouldn't feel comfortable taking apart a laptop computer and getting it back together successfully, then you probably do not want to be doing the electronic portion of this repair.
If you need further advice on recapping, you can post here in this thread!
which caps you need and how many depends on the year model of your LS400
I would advise you pull the ECU and verify the cap values before ordering, to make sure. You can reinstall the ECU in 5 minutes (leave the lower glove compartment out for now) and you can drive the car until the caps arrive in the mail from DigiKey (normally just a couple of days)
WARNING: You must use premium Japanese low-ESR capacitors for this repair to be successful, this kind of capacitor is very rare, they do not stock it locally, you must order it from the links below!
1990-92 LS400 needs 10 or 11 caps as follows:
Qty. 3 of 10μF - 50v
Qty. 2 of 15μF - 35v
Qty. 3 of 47μF - 63v
Qty. 2 of 100μF - 10v
Qty. 1 of 220μF - 16v
1993-94 LS400 needs 8 caps as follows:
Qty. 2 of 10μF - 50v
Qty. 1 of 47μF - 63v
1995-97 LS400 needs 6 caps as follows:
Qty. 2 of 10uF - 50v
Qty. 1 of 47uF - 63v
Qty. 2 of 100uF - 10v
Qty. 1 of 220uF - 16v
1998-2000 LS400 needs 11 caps as follows:
Qty. 2 of 10μF - 50V
Qty. 3 of 47μF - 63V
Qty. 2 of 100μF - 10V
Qty. 1 of 220μF - 16V
Qty. 1 of 33μF - 35V
Qty. 1 of 47μF - 25V (special BP capacitor) - high reliability capacitor, replacement recommended but not critical
Qty. 1 of 330μF - 35V - high reliability capacitor, replacement recommended but not critical
1998 and up owners: you can replace the capacitors of your original ECU without affecting security and the theft deterrent system, but keep in mind that if you get another ECU say from ebay or a junkyard, it will have to be reprogrammed by the dealership or a better locksmith before your car will start with any ECU that is not the original one that came with your car!
WARNING: You must use premium Japanese low-ESR, high temperature, long life, high ripple rejection capacitors for this repair to be successful, this kind of capacitor is very rare, they do not stock it locally, you must order it from the links below!
~~~ CURRENTLY RECOMMENDED CAPACITORS: ~~~
DANGER! - Will Robinson - COUNTERFEIT capacitors are a SERIOUS EPIDEMIC - make damn sure your capacitors come from the factory authorized sources below, those capacitors you found a deal on, on ebay or elsewhere online are very likely FAKES! - most premium Japanese capacitors in the United States are shipped from three principle distributors: Digi-Key, Mouser, and Newark Electronics. Anywhere else is likely a questionable source!
(this list is dynamic and will be updated as Yamae & I find additional good candidates and rule out others)
(recommendations are based on USA availability - the best capacitor made does us no good if it is not readily available)
the voltages specified in the recommended caps below are sometimes higher than the originals, this is a good thing!
the one to get in 10uF is the 50V Chemi-con KZE EKZE500ELL100ME07D - if sold out, use alternate factory authorized source here: EKZE500ELL100ME07D
in the 15uF - the 63V Chemi-con KZE EKZE630ELL150ME11D
also fine is the 100V Nichicon PW UPW2A150MPD
in the 33uF - the 35V Panasonic FR EEU-FR1V330
also very good is the 100V Rubycon ZLJ 100ZLJ33M8X11.5
in the 47uF - the favorite is the 100V Chemi-con KZE EKZE101ELL470MJC5S (sometimes sold out)
also very good is the 100V Panasonic FC EEU-FC2A470
also very good is the 63V Panasonic FR EEU-FR1J470B
in the 47uF special BP - the 35V Nichicon EP UEP1V470MPD
also fine is the 50V Nichicon EP UEP1H470MPD
in the 100uF - the 35V Rubycon ZLH 35ZLH100MEFC6.3X11
also very good is the 50V Panasonic FR EEU-FR1H101
also very good is the 50V Chemi-Con KZM EKZM500ELL101MHB5D
in the 220uF - very impressive is the 50V Panasonic FR EEU-FR1H221
also very good is the 50V Chemi-con KZE EKZE500ELL221MJ16S
also very good is the 50V Panasonic FM EEU-FM1H221
and the new 50V Nichicon HW is my new favorite! UHW1H221MPD
in 330uF - I recommend the 35V Rubycon ZLH 35ZLH330MEFC10X12.5
or alternatively the 35V Panasonic FC EEU-FC1V331
~~~>>> special thanks to world class ECU engineer Yamae from Japan <<<~~~
who got me thinking about how ECU's operate in my head, which lead to this breakthrough! (and also thanks to TV character MacGyver, it's what he would have done!)
no one understands Toyota ECU operation and design on Club Lexus anywhere in the same league with our special Japanese guest Yamae!
just consider him a guest expert ECU engineer from Nippon Denso, and you wouldn't be far off.
ECU removal:
always disconnect the negative battery cable before disconnecting or reconnecting an ECU
beware: there is at least one hidden bolt inside the lower glove box behind a secret panel (not joking about this) the diagram below will help, but it can be a little tricky to get the lower glove box out the first time, just keep at it, and you eventually will locate all of the fasteners
I take NO responsibility for any damage you do to your ECU from any information you obtained from this post. DO THIS AT YOUR OWN RISK!!! If you completely hose your ECU, don't come whining to the cowboy! Nor do I want it sent to me for repair! Untangling someone's 'handiwork' is more frustrating than battling the original problem! If you have any doubts about your skills, DON'T TRY THIS!! - If you do screw it up, it is not the end of the world, just purchase the same part number ECU on ebay from a high rated (99.5%+) seller for around $125 or so and find someone to do this cap replacement job who has experience.
Also - NEVER use 'cold heat' types of soldering irons!! They work off the principle of an ARC welder, and emit a current. This can instantly destroy your ECU board when contact is made. If a good soldering station is not available to you, a 40 watt solder pencil with a standard tip on it will work fine.
STEP-BY STEP REPAIR GUIDE
if you have patience and soldering skill, it's not too difficult!
here is what I did:
CAUTION: BE VERY GENTLE with flexing the 2 or 4 gray ribbon cables that connect the 2 mainboards - they will not tolerate rough handling! - they will take a normal amount of flex required to open up these boards flat for working on them, so you don't have to be a complete scaredy-cat!
parts/tools to round up:
the ECU carefully opened up (be gentle with the ribbon cables)
the new capacitors (you did procure the ones Yamae & I specified above, right?)
rosin core solder 63/37 (Radio Shack p/n 64-015 or equivalent)
rosin solder flux (Radio Shack p/n 64-022 or CAIG DeoxIT rosin flux p/n RSF-R80-2)
40+W soldering iron or soldering station, 75W max - no soldering guns! (Radio Shack p/n 64-2071 or equivalent)
● my favorite soldering station: Hakko FX-888D
● my next favorite: Weller WES51
solder sucker (Radio Shack p/n 64-2060 or equivalent) another type that is also good is Radio Shack p/n 64-210 (some people find this a huge help, I don't use them but very rarely)
stainless steel safety pin or, if available, a stainless steel dentist's pick is also fine of the tip is straight and sharp like a needle
nail clippers or flush cutters (Xuron 9200 or similar)
91%+ isopropyl alcohol
baking soda
vinegar
distilled water
CAUTION: - static electricity can kill an ECU - some people wear anti-static wrist straps, but I find them a pain, here is a better plan and what I do in my electronic's bench: all 100% cotton clothing and bare feet!
FIRST: - take photos of what caps go where originally, plus make a DIAGRAM of cap sizes & placement!
1. - remove old caps using soldering iron heat or desoldering iron and a simultaneous back and forth tug after making diagram of values and placement, just keep tugging, they will come out
2. - gently brush areas of board where caps were using toothbrush with baking soda/water paste to remove any acid leakage residue
3. - wash area with vinegar to remove any caustic base damage
4 - inspect board copper traces to insure that they are still intact, it is OK if they are now a brighter copper color than surrounding traces, but severed or completely eaten away traces will require professional repairs and you are probably better off getting another ECU from a junkyard or ebay and replacing the caps in that one
5. - rinse board with distilled water to remove vinegar acetic acid
6. - rinse board twice with 91% isopropyl alcohol
7. - inspect desoldering job with loupe
8. - using medium large safety pin, re-make holes in desoldered pads in board to accommodate easy installation of leads of the new caps, heat up the solder pad, insert safety pin, let cool and the stainless safety pin will twist right out, leaving a perfect hole for new cap leads!
9. - solder in new caps, double checking polarity (+/- orientation) - use 63/37 rosin core solder, and get some rosin solder flux (I like Radio Shack p/n 64-022) and cover the solder area well - slather it all over where the new caps will be soldered - the new capacitors do not like extended heat, just get in and get out with the soldering iron, and make sure iron is ample wattage (like 40W+) - I do not like to apply heat for over 3-4 seconds at one time. Use LIBERAL amounts of the RS/CAIG rosin flux mentioned above in the parts list, this is the key to making the soldering process behave!
10. - trim leads on reverse side of board of each installed cap with clipper
11. - rewash board with 91% or higher isopropyl alcohol
12. - inspect soldering job with loupe
13. - blow compressed air to make sure no clipped leads or stray solder remain on board, use about 25 PSI or less, it's a circuit board, not a crankshaft!
14. - Once ECU is reinstalled into car and everything is reconnected, only then do you want to reconnect the negative battery terminal
15. - BEFORE cranking engine the first time, click the ignition switch over to the RUN position for 1 minute to let the other ECU components acquaint themselves with the new caps and let them precharge.
updates 10-24-2014
For the '1991 there is a 9 capacitor variant ECU. See post #966
https://www.clublexus.com/forums/ls4...ml#post8721523
1991 there is a 10 capacitor version. See post #975
https://www.clublexus.com/forums/ls4...ml#post8736858
Thanks to Yamae for researching the part#'s for the North American ECU's.
Hi , I have a 93 SC400 and dont know witch ECU capacitors to change and how many , thanks .
Old 01-22-15, 03:42 PM
  #1071
Yamae
Yamae's Avatar
witch?
Ha, ha, I think you are joking. Oh may be Yes, those are like witches. They turn to be dangerous killing the ECU functions and eating traces.
They really are as dangerous as you have a witch wife.
Replace all those electrolytic capacitors before you are eaten. Those capacitors have ID names PF(M) and PR(M).
Regarding the number and others, those are already written in the thread. Search before ask.
See page 33.
Last edited by Yamae; 01-23-15 at 07:41 AM. Reason: To add the page for a convenience.
Old 01-26-15, 01:19 PM
  #1072
HIxUZZ80
HIxUZZ80's Avatar
Default CIrcuit board medics, SC..
does anyone know if thes guys on the east coast do good repairs, or have any experience whit them. cant find anybody in Hawaii to replace the Caps. they say 1 year warranty, 200$
Old 03-22-15, 11:48 AM
  #1073
zeen
zeen's Avatar
Thanks to Yamae and Cowboy for the great information and instructions. I just performed the repair, and it fixed all my drivability problems (rich running, bucking, barely accelerating, etc.) Too bad I didn't join up and read this thread sooner, the O2 sensor errors were a symptom, not a cause of the problems. Oh well, new sensors probably can't hurt at 220K miles. It didn't stop my Trac Off light flashing, so I still have research to do there.
Old 03-22-15, 01:17 PM
  #1074
Snabelit
Snabelit's Avatar
Default Help me My ecu 90661-50310
Hi guys, my name is Dario and I live in Italy I wanted to ask a kindness if you help me, my engine is the same symptoms that are listed in the first page and under your
directions I replaced the capacitors purchased in an electronics store. I do not remember the brand but the MFD were identical to those assembled. I have not solved the problem,
does the exact same problem as I can solve it thanks in advance here and good evening
Old 03-22-15, 04:56 PM
  #1075
Yamae
Yamae's Avatar
Read the post #1 carefully again especially, "it is CRITICAL that the replacement caps be low ESR type and from one of the brands listed above - don't cheap out on your vital ECU!" and cautions.
Sounds like you are showing a bad example of a usage of incorrect capacitors / a incorrect replacing job or the problem is not related to the ECU capacitors. Average electronics stores usually don't carry those low ESR capacitors fully. Even in Akihabara Tokyo where you can purchase any electronics related parts, I have needed to visit 4 different stores.
Old 03-22-15, 05:52 PM
  #1076
rudyH
rudyH's Avatar
Smart engineer explains ESR and POSSIBLE US source.
https://engineering.purdue.edu/ece47...les/lowesr.pdf
Old 03-24-15, 11:59 AM
  #1077
csalazar87
csalazar87's Avatar
Smile It work its works, it really works!
Hi Guys,
I am new to Club Lexus, I just traded in my Civic 01 for a SC400 1992 and I couldn't be happier.
Well, maybe a little happier....so after driving the car for about a month, I noticed that I was getting around 10-12 MPG (I can't be sure since I suspect the Dash has bad caps) but definitely less than 20-22. I had been driving like a granny and to my knowledge this car had been kept up by Lexus dealers only (I.E. Spark plugs, distys, etc)
The power steering pump and alternator had been changed so I ruled out the alternator and I was planning on doing the big three upgrade but I still wasn't convinced that grounding the car would restore my MPG.
That's when I found this thread and I am so happy I did. I am an electrical engineer so as soon as I saw this thread, I had an epiphany. OF COURSE THE CAPACITORS ARE CAUSING MASSIVE GAS FLOODING AMONG SEVERAL OTHER MYSTERIOUS ELECTRICAL PROBLEMS, the smell of gasoline was so prevalent (it caused my girlfriend to make a stink face whenever I started up the car) .
The previous owner had an issue where the battery would die everyday (he did drive about 1 mile to and from a train station so it may have been that he didn't allow for the battery to properly charge but who knows, I haven't had this issue yet but I commute 40 miles everyday). I hope this fixes this issue.
SYMPTOMS RESOLVED
I did notice the sluggishness when the car was fully warmed up however it is even more peppier (after the fix) then a cold start.
For the first time, I am able to break traction from 0MPH so it appears as if the torque is back.
I also floored 6 times going up and down RT4 in Hackensack and usually I would see the gas level decrease immediately. After the fix...the needle did not move.
More to come, this is just from a minimal repair of 2 out of 9 caps
I am somewhat okay at soldering which is why I only replaced the cap below. The rest of the job will be complete tonight since I am going to a friends (and he has a solder sucker...that would have made the process a cinch). I am aware the rest of the caps are ticking time bombs.
Oh and I did order the exact parts from DIGI-KEY (They are really nice but then again most people outside of NJ are).
Replacing the caps PERFECTLY is tricky. You simply need experience and the right tools as with any specialty job. I have many hours of soldering experience but I'd rather take it to someone who can do this in their sleep for peace of mind.
In just replacing one CAP, I managed to damage a trace (however I jumped a lead to the next junction so no big deal for me atleast.) In other words, be careful and patient.
See the crap on the leg! Bad cap...bad cap!
One more thing, it was the original ECU so I'm astounded at the fact that most of these caps lasted this long. Guess I'm lucky
This community is awesome and I plan on contributing as much as I can in the coming months.
More pictures to come
Old 03-24-15, 07:37 PM
  #1078
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus and congrats on the LS. Yes, this fix will do wonders for some of the poor running symptoms.
Old 03-24-15, 08:54 PM
  #1079
Yamae
Yamae's Avatar
Originally Posted by csalazar87
I noticed that I was getting around 10-12 MPG, the smell of gasoline was so prevalent (it caused my girlfriend to make a stink face whenever I started up the car) .
I'm sure your gas mileage will be improved almost twice more and your girl frind will like to drive with you more after you change all those capacitors.
Old 03-25-15, 07:11 PM
  #1080
csalazar87
csalazar87's Avatar
Checking back in
So we completed the repair last night and everything went perfectly!
We found another (visible) bad capacitor for a total of 2.
220uf capacitor [1992 SC400]
10uf capacitor [1992 SC400]
The Usual Suspects.
Word of advice, some of you were saying there was a hard to reach capacitor...we found that tweezers were pretty helpful in guiding the new capacitor in. Other than that, the repair was pretty straight forward.
We installed the ECU and then went for a nice test drive. With overdrive and ECT on I stepped on the accelerator with all my might.
Few noticeable differences:
1.) I used to drive a civic...so I have never felt that sensation of sinking into the seats at full throttle so there's that.
2.) I still have gas! I had a little more than quarter tank last night....drove back from my friends house and to/from works for about 70 miles total and I'm at 1/4 tank.
3.) Engine sounds different but in a good way, I would describe it as 'more growly'.
4.) Gas smell is gone, Girlfriend is happy (and we're going on a road trip to Connecticut this weekend. Now, we don't have to take her volvo c70)
5.) White smoke is gone.
6.) Way more torque, like spill your drink easily kinda torque.
That's about it. Happy as hell...Next, is to re-ground/upgrade ground connections, timing belt, dash-caps, replace antennae and I'm done! Everything else is in perfect shape.
I will perform a full tank test on my road trip this weekend with the final MPG results.
Thanks everyone!
Quick Reply: All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
