Post up your Rear muffler set-up!!! In need of inspiration!!
#32
FYI, most any straight thru muffler or resonator will do little to dampen sound, but will reduce some raspiness. To dampen sound you'll need a muffler with some bends (offset inlets and outlets) inside or internal baffles.
#33
BahHumBug
if you have some reputable source to back that up other than hearsay please feel free to share.
#36
this isn't true at ALL. please check your information rather than post misinformation. Straight through mufflers, when properly designed, can give more than adequate sound levels.
#37
BahHumBug
How about personal experience. I can appreciate that you're a MOD, but there may be someone out in the world that might know a thing or to also. On my Audi A4 I did a full stainless exhaust with single Magnaflow round mufflers and 2 stainless resonators, all of this was after a large turbo which tend to act a little like a muffler also. I had to add two more offset inlet/outlet mufflers to make it quiet enough to where I felt comfortable letting my then 3yo daughter ride in the car. Like I said before, just cause I'm new here doesn't mean I'm new by any means. I've owned, built, and modded over 20-25 cars in my life not counting the ones I haven't owned.
really?
common sense dictates that in terms of sound level: car with more mufflers < car with fewer mufflers, regardless of type.
the only way your example would be valid is if you set up a straight through exhaust in the same basic configuration as your previous/factory exhaust and compared the sound. going from 2-3 mufflers to 1 then blaming the muffler design for it being to loud is rather pointless.
I was looking for a copy of an article GRM did a while back, comparing a ton of different mufflers for backpressure, power, and sound. Doesnt seem to be available publicly so this should hold you over for now.
http://www.motoiq.com/magazine_artic...st-system.aspx
#38
The 1.8t is a single into a dual muffler system. I had the system built as a single into dual as soon as the downpipe bent under the car. The round Magnaflows I ran where 18-20" long if I recall correctly and the after it was too loud, then I added the offset mufflers on each side at the end of the system. Also, I said straight thru mufflers would not do much for reducing sound levels, when I said that I was referring to a muffler you can basically see through the inlet/outlets, not a chambered or baffled muffler. I think that may be where our confusion with each other may be. Yes a baffled or chambered muffler with center inlet/outlet will reduce sound quite good.
#39
BahHumBug
please reread my initial statement. I am stating that a properly set up straight through muffler based system will give more than adequate sound levels and better performance than a chambered/baffled muffler.
you realize they make straight through mufflers with offset inlets/outlets right?
#40
#41
#44
Drone will be an issue with almost any dual exhaust, how much drone is the the question. Pure Drifter is right, and I think he means from the gains you'll get with the exhaust the mufflers will cause only minimal loss
Last edited by PureDrifter; 07-03-12 at 02:53 PM. Reason: corrected as per 2nd post.
#45
I removed the middle resonators, which are more like mufflers when I cut into them. Then I replaced it with 2.25 inch pipping. Then I cut the oem mufflers off and replaced them with oem style magnaflows and cut the factory tips and hangers off the old mufflers and welded them up. The car has a nice deep sound when at idle, and a great sound when driving. It also is not annoying on the highway, in fact it almost sounds stock unless you put your foot into it. I did not want the car to sound like a mustang, just my opinion.
