97 rear coilover installation
Old 02-15-12, 03:39 PM
bwils
bwils's Avatar
Default 97 rear coilover installation
How do i get to the rear top mount so i can install my coils?
Old 02-15-12, 03:51 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the trunk liner has nothing to do with either the coilover install or the high mount stop light.... gather yourself and reword your question.
Old 02-15-12, 04:42 PM
billydpowe
billydpowe's Avatar
Originally Posted by bwils
I'm trying to remove the trunk liner and im stuck because the top light. Could someone tell me hwo to remove this light before i break it lol. Also once the liner is out will i have access to the bolts or do i have to remove anything else?
you dont need to take it out, but it comes out from inside the car......
if you dont know what you are doing, do a search, and see what others have done..
do a little reading and find out the tricks...
Old 02-15-12, 05:48 PM
RA40
Super Moderator
RA40's Avatar
Welcome...this should get you going:
https://www.clublexus.com/forums/ls4...t-install.html
Old 02-15-12, 06:00 PM
PureDrifter
BahHumBug
reading the stickies will help you a LOT....
the rear shock mounts (i'm assuming that's actually what you're aiming for...) are accessible from inside the car, after taking the rear seats out and lifting the rear deck (after removing the subwoofer cover, not the high mount stoplight). you can't access the mounts at all from the trunk.
searching and the FAQ will help.
Old 02-15-12, 06:59 PM
bwils
bwils's Avatar
yeah jus noticed the stickies. thanks guys
Old 02-15-12, 07:04 PM
imdanomite
imdanomite's Avatar
pop up the rear seat bottom. unbolt the rear back rest (hidden bolts near the head rests). then you'll see covers for the strut mount. remove that and you can get to the nuts for the strut mount. you don't have to take out the rear shelf or subwoofer. pretty simple
Old 02-16-12, 09:00 AM
bwils
bwils's Avatar
Default need help with coilover installation
how do i loosen the lower strut bolt behind the rotor? its stuck sooo tight . i'm all the way done besides this one thing, i can't stop now lol.. what u guys think would help me get it loosend and off??
Old 02-16-12, 12:49 PM
PK_Celsior
PK_Celsior's Avatar
use some wd-40 and let it soak than use a breaker bar if you have an impact even better
Old 02-16-12, 04:17 PM
bwils
bwils's Avatar
so i got the 2 rears all good to go. but the fronts are even tighter!! lol. snapped a wrench and couple extenders. i might just have to take it to the shop for the fronts, i sprayed the **** out of it with WD-40 nd let it soak for an hour and smacked it with a hammer also to maybe loosen something up. but nothing.
Old 02-16-12, 04:26 PM
PureDrifter
BahHumBug
http://bit.ly/wB2P3a
Old 02-16-12, 08:23 PM
xtremex626
xtremex626's Avatar
if i can do my whole suspension by myself without any directions, you can too.
Old 02-16-12, 08:40 PM
Luxurexus
Luxurexus's Avatar
PD, you so funny.
Old 02-16-12, 09:42 PM
RA40
Super Moderator
RA40's Avatar
PD has his charms.
Let the penetrant soak in then have another go. Short of that, these big bolts/nuts do get pretty stiff over the years. An impact gun does wonders. Laying on your back or on your knees in a driveway is a difficult position to get good leverage.
Old 02-17-12, 01:24 PM
bwils
bwils's Avatar
so i got the bottom bolts finally cracked loose. now i'm having trouble gettin the strut out. do i need to undo anything or else or should there be enough room and i jus need to play with it more?
Quick Reply: 97 rear coilover installation
