a/c or heater doesnt blow hard
Old 02-13-12, 08:27 AM
jknguyen80
jknguyen80's Avatar
Default a/c or heater doesnt blow hard
my cars a/c when its on or the heater even a full blast doesnt blow that hard. ive been in my friends gs300 and his blows really hard. what problem could this be? thanks
Old 02-13-12, 09:39 AM
billydpowe
billydpowe's Avatar
What are you driving???
Old 02-13-12, 01:44 PM
steve2006
steve2006's Avatar
Good question Billy.
Assuming it is an LS400 the first thing I would check for poor airflow is the pollen filter which will probably be unchanged for years and completely clogged up.
Also lift the hood and take a look at the air intake vents between the wiper arm spindles these also collect debris causing poor airflow.
Old 02-13-12, 03:27 PM
FireEMT978
FireEMT978's Avatar
I absolutely second the pollen filters. When I got mine, I just chose to check them out, and they were blocked completely solid. The were original, with 140,000 miles on them.
Old 02-13-12, 03:35 PM
Lavrishevo
Lavrishevo's Avatar
WOW, 140,000 on a single cabin filter... That is rather disgusting
Old 02-13-12, 03:43 PM
FireEMT978
FireEMT978's Avatar
They definitely were disgusting. I had to get my small wet/dry vac with some homemade attatchments to suck up the garbage that was left in the blower housing.
Old 02-15-12, 09:41 PM
jknguyen80
jknguyen80's Avatar
96 ls400. damn i guess i need to check mine. where is the pollen filer located in the vechicle? thanks
Old 02-15-12, 11:21 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
rear of glove box, it's actually in your owner's manual believe it or not.
Old 02-16-12, 10:10 AM
FireEMT978
FireEMT978's Avatar
As for my 93 LS, they were located BELOW the glove box, but it was necessary to remove the panel below the dash to get access.
Old 02-17-12, 05:44 AM
BobN54
BobN54's Avatar
Instructions for changing it are in your owner's manual. The one on my LS400 was all clogged up when I bought the car. Easy fix, though getting the access panel back in place just right is a little frustrating.
Drizzle66
21
06-30-22 08:39 PM
Scorny
10-03-12 11:14 AM
Lexus1994
11-01-11 04:02 PM
The Ikon
05-11-01 01:53 PM
The Ikon
05-10-01 03:01 PM
Quick Reply: a/c or heater doesnt blow hard
