Fluid flush order?
Fluid flush order?
I am aware of the wheel order to flush the brakes. But, what I am wondering is if there is a sequence in the order of if I should flush the brakes, then the TRAC system, or vice-versa? Also, would there be any issue to do one, but wait a week to do the other due to time constraints, or will that cause old fluid to mix with new?
BahHumBug
http://www.lexls.com/tutorials/brake/bleeding.html
no point to doing a little bit at a time, if you're trying to replace the fluid you need to do it all at once.
Purplexed
Maintenance
05-29-01 08:40 AM
