96 ls400 whole front vibrates
Old 11-30-11, 04:49 PM
trinils97
trinils97's Avatar
Default 96 ls400 whole front vibrates
So when my car hits 60 mph the whole front shakes like the wheels wants to fall out . The upper control arm was bad , I changed it an its still vibratein . Thought the wheel needed balanceing , nope that's not it . Any ideas to what else wud cause it?
Old 11-30-11, 07:51 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
front strut rod bushing, though if its related to speed it's more likely a wheel or hub issue.
Old 11-30-11, 08:51 PM
RA40
Super Moderator
RA40's Avatar
Switch the wheels around and see if the vibration changes. Then you can be sure it isn't that specific wheel/s as the cause. A road forced balanced tire is a good start and tracing though the front suspension for obviously worn bushings next.
How many miles on your car? As they age, many of those bushings will be showing signs of wear. That may be the UCA's LCA's, engine and tranny mounts and the infamous strut bar bushings. If there are any imbalances caused by tires or hubs, this may present itself in this manner.
Old 11-30-11, 10:49 PM
Mugen_1
Mugen_1's Avatar
When my '97 (approx 157,xxx) developed a glaringly apparent shaking at around 70 mph, the culprit turned out to be a rear tire with a slipped belt. Just put the winter tires back on, and it's smooth sailing.
Old 12-01-11, 09:06 AM
trinils97
trinils97's Avatar
I changed the upper like 2 days ago it helped a lil bit still vibrates . Car has 147.xxx miles . I also switeched the back to the front on the side dats vibratein an still no change . It has a lil play still so might be the strut rod bushin or lca . I've had 3 l's an they always wana act up in the winter smh..
Old 12-02-11, 01:21 PM
paulwall86
paulwall86's Avatar
Does it only do it when your at 60? and also do you hear a slight scraping noise? if so check your calipers.
Old 12-02-11, 06:55 PM
AzHotLS
AzHotLS's Avatar
I was thinking warped rotors, but you'd prolly notice vibration at lower speeds too so maybe not.
Old 12-03-11, 07:33 AM
trinils97
trinils97's Avatar
Found the problem bad tire.. seems like the belt shifted in the tire . When I looked @ it the tire looked fine . I swictched it with the spare , no more vibrations =)
Old 12-03-11, 07:34 AM
trinils97
trinils97's Avatar
Ohh the vibration was mainly on the drive side so originally I only rotated that one . An finally said let me try the passenger side
OMAHA
10-30-18 10:13 AM
shaft1
16
06-24-13 10:13 PM
tanyet
12
07-24-11 05:51 AM
98LSfromNJ
07-26-09 05:05 PM
stickyrick
04-06-09 06:47 AM
Quick Reply: 96 ls400 whole front vibrates
