I have a problem with the dashboard
I have a Lexus LS 400 1994. I have a problem with the dashboard. The dashboard will not light up there is no light at all meaning we cannnot see the gadgets (speedometer, RPM, fuel, & temperature). During the summer when the temperature is outside is more than 70 degrees than the dashboard works even the lights on the dashboard. First the lights on the dashboard will start blinking, and than it turns completely on. However, when we turn on the air conditioning in the car after awhile the lights on the dashboard would start blinking and it will turn off. That's when the temperature in the car goes below 60 degrees. During the winter the dashboard does not turn on at all. We have checked the fuses and all of them are working properly. The head lights and the brake lights and back lights are all working. All the lights inside the car and the turn signals are working. We have installed an new dashboard and the same thing is going on. If you can be so kind as to give us some advise as what to do to correct this problem. We are also asking if you can send us a copy of the wiring diagram of the car Lexus LS 400 1994. My email is dulitl76@gmail.com. Thank you Dusan Vasiljevic
I had similar issues, with my instrument cluster. I had also replaced the bad caps, to no avail. $80 flat to www.bba-reman.com/uk/index.aspx and my lights don't dim or flicker, my fuel gauge works, my speedometer doesn't stick. And there service is backed y a 2 year warranty. I'm very pleased.
Scythe
11-01-07 12:59 PM
cyberseano
12-03-03 09:04 AM
