sub making engine noise need help
Old 06-21-11, 12:37 PM
jediredeye
jediredeye's Avatar
Exclamation sub making engine noise need help
subwoofer makes the same sound as car idle but when i turn up the volume it gos away i think its my ground but idk
Old 06-21-11, 03:52 PM
tenchu
tenchu's Avatar
Did you run the wiring, or did a shop? Likely cause is your power wire crosses with your RCAs at some point. Its always best to run these on opposite sides of the car, Power/Remote on one side, RCA on the opposite.
Old 06-21-11, 08:11 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
its the magical power of the universe surging through your car.
we can't really tell you anything if you both give us no information, then don't ask any kind of question...
Old 06-25-11, 09:41 PM
filthyLS4
filthyLS4's Avatar
exactly what he said!
Old 06-25-11, 09:42 PM
Miguel1989
Miguel1989's Avatar
It's usually just cables being crossed just re-check ur wiring and u should be cool I had the same problem
Old 06-25-11, 09:52 PM
My92SC300
My92SC300's Avatar
Engine noise through speakers in most cases is either a bad ground, or your rca's are too close to your power wire. If you look at most amps, they have the rca outlets on opposite sides from the power & ground outlets.
Old 06-26-11, 10:41 AM
Rey
Rey's Avatar
Reiterating what everyone else said; ground loop or interference through RCA's.
ESeries300
03-25-11 05:21 AM
balticbsc3
03-01-06 12:37 PM
TriniLex
12-13-05 07:20 PM
Philly#1 Lex
09-13-03 05:42 PM
j2tha0e
03-25-02 07:37 PM
Quick Reply: sub making engine noise need help
