help help transmission codes sho wants to charge me over 800
they got code
63 - Open or short circuit in no. 2 solenoid valve
and
67 - OD direct clutch speed sensor signal malfunction
i need help if anyone can help me with instruction on how to do this i been to 3 different shop and all of them want over 800 for this job and i dont have the money to spen 800 on this sensor i have change the transmission fluid before all i will need is the location of the sensor for code 67 and the location of the solenoid for 63 can someone help me with this problem
and
Why search when you can get someone else to do it!
https://www.clublexus.com/forums/sc-...placement.html
You owe me a steak meal in Chucks, Ft.Lauderdale next time I'm over there lol.
The $159.00 kit on the last post link looks good as there is no modification bracket to fit and you get all 3 solenoids so should be plug and play.
Post up the results when you get it sorted.
my transmission is a341e i only have t kits one for $160 and one for $600
http://www.makcotransmissionparts.com/97420AK.html
http://www.makcotransmissionparts.com/97420BAK.html
im going to buy the kit for 160 and them just work with that it will be just plug and play i will also change the filter and gasket
i change my solenoids i had the code 63 and 67 i change them and now i still have the same problem the od lights keep flashing. i change the filter also i took of the battery and the fuse in the engine to reset the computer but it didnt work i still have the same problem like if i have not change anything. what can i do
You have replaced the solenoid but did you check all the wiring from the solenoid to the transmission ECU? A break in the wiring anywhere between the 2 would give the same codes.
Code 63 does not specifically mean that no2 solenoid is faulty if a wire has broken or shorted out to that solenoid it would also give code 63.
i did check the wire of both and they were fine no cracks or anything similar they were away from moving parts i talk to a mechanic today and he said that the sppen sensor can be the one giving me the codes again, he said the solenoids that had the problem coukd have damage the speed sensor and now is not working properlly
