No dimming, running lights out...
Old 04-04-10, 10:27 AM
Acidic
Acidic's Avatar
Default No dimming, running lights out...
My running lights are out and the dash won't dim. Also the night time lights on the HVAC and radio won't come on... it's like the car doesn't realize I've turned the headlights on... Anyone know why this might be happening?
Brake lights work. The dash dimmer does NOT work. The HVAC and radio LCD's work but they don't light of for night driving
Old 04-04-10, 10:39 AM
Acidic
Acidic's Avatar
By the way I did check the fuse (#13) and the wiring harness in the trunk. The harness looked fine...
Old 04-04-10, 01:27 PM
Acidic
Acidic's Avatar
I'm going to put my money on some sort of relay since it was all working the day before and the fact that several diff systems on diff harnesses and fuses are affected...
Old 04-04-10, 03:00 PM
Acidic
Acidic's Avatar
After some more searching it's def the tail light relay. Does anyone have a schematic something to show me where/how to replace this? It appears to be in with the fuses but I don't know where... also is there a way to swing the4 j/b down where it is easier to access? They sure put it in a PITA spot
Old 04-10-10, 04:35 PM
Acidic
Acidic's Avatar
I did troubleshoot it today and it was the relay... I had to go to the dealership to get a new one but better than throwing parts at it.. the toyota TIS is an awesome deal btw! The power window relay was the same so I swapped it over and I'll get it fixed when the part comes in...
Old 03-16-11, 04:36 AM
Max Power
Registered User
Max Power's Avatar
Thanks for this thread. even though no one replied to you.
I am having the same problem as of 30 minutes ago.
Old 04-29-11, 03:24 PM
Max Power
Registered User
Max Power's Avatar
anyone got anymore info on this?
Old 05-02-11, 06:11 AM
Acidic
Acidic's Avatar
What exactly do you need? I actually have a spare relay if you want to purchase it..
Riztnack
01-27-17 04:49 AM
GRAMPZ
12-29-14 10:46 AM
RIP TimmyD
Lighting
09-17-09 12:52 AM
kayexalate
11-16-08 02:46 PM
Quick Reply: No dimming, running lights out...
