Stereo LCD Light
Old 04-24-11, 05:03 PM
nordoyan
nordoyan's Avatar
Default Stereo LCD Light
So, my amp and sub went out on my 94 LS4, and I got a after-market sub and amp. the guys who installed it somewhat messed up my stereo. Now that when the headlights are off my stereo lcd displays lights are on and when I turn on the headlights those lights turn off even if i turn just the daylight driving lights on. I have looked at wiring diagrams and everything but can't figure out which wire is the one that was connected incorrectly. I appreciate the help.
Old 04-24-11, 05:51 PM
emarknot
emarknot's Avatar
are you sure the control for the dimmer didnt get bumped or messed with ?
kinda sounds like it to me.
Old 05-01-11, 09:48 PM
nordoyan
nordoyan's Avatar
i have no idea, but where is that control?
Old 05-01-11, 09:51 PM
AzHotLS
AzHotLS's Avatar
From memory, below the instrument cluster on the left side of the steering wheel.
Old 05-01-11, 09:54 PM
Hilux22RE
Hilux22RE's Avatar
the dimmer is on the Left side of the Dash. Under Instrument Cluster sounds like its turn all the way down or there might be a short in the System...
Old 05-02-11, 12:21 AM
nordoyan
nordoyan's Avatar
thanks for the replys but its not my clusters lights that are out....its when i turn my headlights on the stereo LCD backlight turns off the place where it says
CD 1 Track 1
at night I can't read those because the backlight is off when the headlights get turned on
Old 11-20-11, 03:02 AM
nordoyan
nordoyan's Avatar
anyone any ideas?
Old 11-20-11, 03:43 AM
LJBSJB
LJBSJB's Avatar
Sounds like a harness connection issue. Did they splice into a wire and overload or break a circuit? An ugly diagnosis situation....
Old 11-20-11, 09:55 PM
whit3b0y
whit3b0y's Avatar
I don't really see how this would have happened just installing an amp and a sub, A deck, yes that's understandable since the lights go through the deck. try elimination, Using a test light pull the deck and check all the wires with the stereo off, on, lights off, on....
Yaj95ES300
03-16-09 10:54 AM
lex2001
01-09-09 04:42 PM
RamshakleZ
05-09-07 11:56 AM
FILIPE
Maintenance
10-04-03 06:17 PM
Quick Reply: Stereo LCD Light
