Serpentine Belt Replacement
Old 08-21-02, 10:23 AM
FusionMan79
FusionMan79's Avatar
Default Serpentine Belt Replacement
Anyone have any tips on replacing the serpentine belt? Mine's running out of the proper range on the tensioner markings. Is it possible I need to replace the tensioner? What are the signs of a bad tensioner? Do I need any special tools to replace the belt? Do I have to make sure certain pulleys are lined up? Thanks for any info.
Old 08-21-02, 07:53 PM
hyperopt
hyperopt's Avatar
Default Re: Serpentine Belt Replacement
Notchy bearing,
spring losing tension = slip belt.
No, use any tool (eg. long screw driver) to move the tensioner pulley against the spring (counter-clockwise) to create slack in the belt for removal.
No, but do make sure the belt's ribs mate with the pulley's ribs correctly.
Old 08-21-02, 09:20 PM
FusionMan79
Thanks hyperopt. Very helpful.
landarc
07-18-18 10:57 AM
Makiavelo7
GX - 1st Gen (2003-2009)
12
05-18-17 02:01 PM
gs300by
01-15-16 06:21 PM
sc300work
Performance & Maintenance
06-05-15 02:39 PM
UDel
Maintenance
11-26-11 07:55 PM
Quick Reply: Serpentine Belt Replacement
