Program a remote alarm fob for 1996 Lexus 400
Old 01-27-11, 09:53 AM
Nikkc1
Nikkc1's Avatar
Default Program a remote alarm fob for 1996 Lexus 400
I just got this car and I need to program the alarm fob. I have the correct one but no instructions. I need help...
Old 01-27-11, 05:00 PM
Jdilla7
Jdilla7's Avatar
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Press any button on remote for a minimum of 1 second.
System should now lock and unlock doors once.
6. Close and open drivers door.
7. Press any button on remote for a minimum of 1 second. System should now lock and
unlock doors. Once to confirm programming, twice to indicate programming failed.
8. Repeat steps 5, 6 and 7 for additional remotes.
hoonami
04-29-23 09:46 AM
nesby
RX - 1st Gen (1999-2003)
03-25-19 06:56 PM
njes300
08-26-16 02:27 PM
REELhybrid
02-24-06 03:22 AM
Quick Reply: Program a remote alarm fob for 1996 Lexus 400
