96 LS400 no start? (no codes, new battery, new starter 1 yr old)
Old 12-02-10, 07:27 AM
bicol-ini
bicol-ini's Avatar
Default 96 LS400 no start? (no codes, new battery, new starter 1 yr old)
hllo, my car just after thanksgiving, just wont start during the first try, no codes, starter and battery just replaced 1 year ago,
funny thing is if i press lock and unlock 3 times on the remote itll start right away after overnight parking, then it starts right back after i drive for work,
am a little confused but its a hit and miss on the starting, any opinions, maybe my starter is again acting up hopefully not,
Old 12-02-10, 09:40 AM
billydpowe
billydpowe's Avatar
wow, that is a new one on me... hope someone smarter than me can help you.. if your key had a "chip" in it, I would think it was faulty, but the 96 is ordinary.
good luck, keep us posted.. if you can..
Old 12-02-10, 09:44 AM
steve2006
steve2006's Avatar
The same thing happened to mine after rebuilding the starter and a new battery and it was a loose battery terminal,a quick tighten with a 10mm sorted it
Old 12-02-10, 12:56 PM
AzHotLS
AzHotLS's Avatar
Are you getting a single click? Turning over but not firing? Explain further with what happening when trying to start.
Old 12-02-10, 02:28 PM
bicol-ini
bicol-ini's Avatar
hi, yes just a single click, i checked all the obvious and cant come up with an idea i have a tsrm for the 96 LS400, which says that,
ST040–01
STARTING – STARTING SYSTEM
ST–1
1996 LEXUS LS400 (RM439U)
STARTING SYSTEM
ON–VEHICLE INSPECTION
NOTICE:
Before changing the starter, check these items again:
 Connector connection
 Accessory installation, e.g.: theft deterrent system
since every time it wont start, ill hook up an OBDII scanner and to see if any codes register, after that itll just fire up
if the above doesnt work ill lock and unlock 3 times using the remote and itll fire right up no problem
Old 12-02-10, 02:51 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
did you have an aftermarket alarm installed?
Old 12-02-10, 02:57 PM
bicol-ini
bicol-ini's Avatar
no its the original alarm, remote has new battery in it
Old 12-02-10, 05:02 PM
bicol-ini
bicol-ini's Avatar
ive also check the door ecu operation, per tsrm, all checked good. still confused, so am thinking the starter is acting up, ill check for nippondenso pricing,
Old 12-02-10, 07:46 PM
randal
randal's Avatar
So, what happens if you only lock/unlock 2x? 1x? Does it refuse to crank?
If it does not repeatedly give you the same results, then it is just coincidental and your starter solenoid is shot. If it does repeat exactly(3x each time), then it most likely is alarm related.
Old 12-02-10, 07:58 PM
JimsGX
JimsGX's Avatar
Try moving the shifter to neutral and see if that works.
Old 12-21-10, 08:28 PM
bicol-ini
bicol-ini's Avatar
turns out it was the starter, got a reman denso, all is well now,
Old 12-21-10, 08:54 PM
RA40
Super Moderator
RA40's Avatar
Ouch. Glad you got this figured out.
BTW, how much was the starter? I better start planning now for the next one. Hahaha...
Old 12-21-10, 08:59 PM
bicol-ini
bicol-ini's Avatar
132.68 bucks at amazon free shipping
denso part#280-0165
nordoyan
14
10-17-22 05:05 PM
Kevin85
02-03-14 07:55 AM
stk7741
09-12-11 01:19 PM
m1tk4
RX - 1st Gen (1999-2003)
16
11-21-09 06:18 PM
MadMaxxNA
11-17-06 02:27 PM
Quick Reply: 96 LS400 no start? (no codes, new battery, new starter 1 yr old)
