Please Help! Rim/Wheels are hitting calipers
Old 11-20-10, 07:58 AM
JeffsLS400
JeffsLS400's Avatar
Default Please Help! Rim/Wheels are hitting calipers
My new rims are hitting the calipers and won't spin! Can I get spacers to change the offset or am I screwed??? Please help!
1998 LS400.
I bought 18" Diablo Vienna rims (5x114.3), with Nitto NT NeoGen 225/40/R18s. The 'spokes' on the rims curve back (inward) and that's what's hitting the caliper. Goodyear was able to get them all mounted on car, then when they got it off the lift and on the ground they realized they wouldn't spin... at all. Can I get spacers? If so, any idea what size or where?
Thanks much
Old 11-20-10, 08:10 AM
LiCelsior
Retired
LiCelsior's Avatar
do u know how much more clearance u need? pepboys sells some universal spacers but there only like 3mm. wheel width and offset would help also.
Old 11-20-10, 10:11 AM
Raddison
Raddison's Avatar
Yes you can offset them.
Old 11-20-10, 11:33 AM
Revoked911
Revoked911's Avatar
You should probobly do away with your current wheels and get some that actually fit your car. Sure you could get some spacers and fix your current problem but in a month you will realize you have no fitment and wish you had lower offset wheels.
Old 11-20-10, 01:07 PM
RA40
Super Moderator
RA40's Avatar
Welcome to CL...
Verifying vehicle fit prior to ordering is important. To clear, you'll probably need either 10-15mm spacer and depending on the offset, you may rub. The rear no problem but they will probably look sunken in compared to the front so if you want to match, that means spacers in the rear too. For about $225, you'll be rolling.
The better solution is getting wheels that fit properly with high disk brake clearance in front.
Old 11-21-10, 02:54 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
also, buy tires witht he proper load rating and overall diameter.
225/40-18 is the wrong OD for your car, and is likely not load rated to the weight of it.
a 255/40-18 or a 245/45-18 is a better fit.
Old 11-23-10, 12:35 PM
VIPLexy650
VIPLexy650's Avatar
yeah you can get spacers almost anywhere but make sure you wont haave ur wheels rubbing on your fenders. get them rolled. thaths what i did.
byefi
03-28-18 08:39 PM
grantwils
01-31-18 06:49 PM
pnwIS250
02-15-15 01:49 PM
CelsiorAUS
09-07-10 02:51 AM
aaronjz
Suspension and Brakes
04-11-07 05:35 PM
Quick Reply: Please Help! Rim/Wheels are hitting calipers
