High Idle (Rpm's) or Not
Old 10-19-10, 11:16 AM
jgabem
jgabem's Avatar
Default High Idle (Rpm's) or Not
What should the idle speed be (in rpm) at startup on my 1996 LS400. My cars rmp's are at 1200-1500 at startup and then drop to about 800-900 after driving it for a little while, seems like the engine sounds loud.
Old 10-19-10, 01:35 PM
3UZFTE
3UZFTE's Avatar
The RPMs are normal, it's called a cold start. The engine goes into open loop and runs strictly off of memory. At this point, the vehicle usually is running rich in order to heat the engine safely. Once it becomes warm, it reduces the speed at which the engine needs to run and that usually tends to be around operating temperature. Once it hits op temp, it goes into closed loop where it runs according to the ECU fuel strategy which uses O2 sensors to relay the signal. Check your oil and gaskets, usually maintenance items will solve your issues.
Old 10-19-10, 04:26 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
still high, shouldnt be >750 at all.
iirc OEM spec is 650 +/- 100rpm
Lexus082
Performance & Maintenance
12
05-20-24 01:25 PM
MattLS400
190
03-18-21 03:28 PM
gsCrazy
02-02-07 05:20 AM
v8pwr
12
03-05-02 01:54 PM
Quick Reply: High Idle (Rpm's) or Not
