Steering Hard And gets Harder while driving
Old 08-08-10, 11:07 AM
malikqais
malikqais's Avatar
Default 2000 LS400 Steering Hard And gets Harder while driving
Hi,
Guys I have recently changed my tyres and rims to 245/45/18
And done the wheel allighnment also. Now my steering wheel is very hard to turn. Also I flushed the all power steering oil and also put my car on jacks to check if its wheels are causing this, but no, Its hard while on jacks also. Don't know what to do.
And also there is no leaks and no noise in the power steering. Is the alighnment guy did something, any suggestions. Note that some times it becomes ok also.
Thanks In Advance.
Old 08-08-10, 11:56 AM
LiCelsior
Retired
LiCelsior's Avatar
u used transmission fluid for the power steering right.......
Old 08-08-10, 02:51 PM
python
python's Avatar
u got air still in the system
Old 08-08-10, 03:12 PM
steve2006
steve2006's Avatar
Have you cleaned the rack solenoid filter? as it sounds like a line pressure issue i.e. something blocked/clogged, is the serpentine belt tension correct even though it is auto tensioned,make sure the correct fluid is in there.bleed the system again.
Check all the suspension joints for stiffness (top and bottom swivel joints)
last resort is a defective pump or rack
Old 08-08-10, 05:31 PM
python
python's Avatar
u can check for a blockage in the lines by disconnecting ur return line at the pump and it should flow freely,if it spits and sputters there is blockage like u ate a ton of cheese the night before
Old 08-09-10, 01:34 AM
malikqais
malikqais's Avatar
Thanks Guys
I used transmission oil in steering and yes its original from toyota atf-4.
And can you please tell me where is rack solenoid filter?
Old 08-09-10, 02:59 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
uhh the power steering fluid is supposed to be normal dexron III/mercon spec, NOT toyota fluid.
Old 08-09-10, 06:01 AM
lexuslspro
lexuslspro's Avatar
x2...I think you need to drain what you've put in.
Old 08-09-10, 06:32 AM
LiCelsior
Retired
LiCelsior's Avatar
er what ur not suppose to use toyota trans fluid? that doesnt make sense..
Old 08-09-10, 06:34 AM
lexuslspro
lexuslspro's Avatar
In my Volvos and now in my Lexus I've found them all to use dexron III/mercon spec for power steering. It's in the manual too.
Old 08-09-10, 06:46 AM
LiCelsior
Retired
LiCelsior's Avatar
yea that i know but i didnt know using oem toyota fluid was bad.
Old 08-09-10, 07:34 AM
python
python's Avatar
u can use type 4 with no issues
Old 08-09-10, 10:48 AM
lexuslspro
lexuslspro's Avatar
I have heard that type 4 is backwards compatible with type 3.
Old 08-09-10, 02:08 PM
PureDrifter
BahHumBug
toyota t-iv is backwards compatible with toyota t-ii and tiii, but these are NOT the same as Dexron 3/mercon spec fluid in ANY WAY.
Old 08-09-10, 02:32 PM
lexuslspro
lexuslspro's Avatar
Oh that's very good to know...especially if you are draining your transmission fluid and refilling::
Thanks!
Quick Reply: Steering Hard And gets Harder while driving
