1993 LS400 AC Schrader Valve Core Replacement Part
Old 07-09-10, 04:32 AM
eallum
eallum's Avatar
Default 1993 LS400 AC Schrader Valve Core Replacement Part
Hi,
I have leaking both the low and high side AC valve cores leaking on a 93 LS400.
Are these valves replaceable? Assuming they are, what type/size of valves, part # or where to order from?
Thanks
Edwin.
Old 07-09-10, 05:03 AM
python
python's Avatar
any parts store should have em
Old 07-09-10, 01:13 PM
williamb82
williamb82's Avatar
i buy replacements at napa. less then $2.00 each
Old 10-01-14, 05:47 PM
oldskewel
oldskewel's Avatar
Default Which type of Schrader valve core?
Does anyone know which type of Schrader valve core is used in the AC on my '91 LS400? (and are they all the same throughout?)
I'm still running the original R12, in case that matters. The high and low side ports both seem to leak a little and I'd like to replace the valve cores. I've been successful at pulling the poppet tighter, and finding the best angle to slow the leak almost to a stop. And with the caps on, nothing is detected by my leak detector, but still I'd like to fix it right.
My guess for now is "Standard". I think this is the GA1528 as shown on http://acvalvecores.com/products.html
Old 10-02-14, 05:33 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
once you vacate your system of R12, you will need to retrofit to R134 anyway which will come with new fittings. they don't make R12 readily available anymore.
Old 10-02-14, 11:23 PM
oldskewel
oldskewel's Avatar
I'm still running R12 with no problems and no plans to evacuate it or switch to R134a. I will replace the cores with the system fully charged.
So I still need to know which type of cores it has, in case anyone knows.
Old 10-03-14, 10:20 AM
billydpowe
billydpowe's Avatar
just take one out of your left front tire, they all fit.... plus yours are probably just loose... tighten them up... oh you want to know where to buy the tool?? think about it, I gave you a hint...
smiles, just joshing you... we wish that was our only problem..
Old 10-08-14, 12:56 PM
edd6499
edd6499's Avatar
Default AC Issues
Not sure where to post this - 1998 ls 400. Had the comp. clutch fail, so replaced the compressor with a reman. denso and replaced the dryer. Vacuumed the system down and held a vacuum just fine. Problem is that I can not get the system to take more than about 1/2 a can of 134. Had it vacuumed, released the first can, began to fill, then just stopped filling. Started the engine, turned on AC to see if that would help, but would still not draw it in. compressor engages for about 3-4 seconds, then the light starts flashing and the compressor shuts off. Any suggestions would be appreciated. Thx.
Old 10-08-14, 05:30 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
compressor shuts due to low refrigerant most likely. are you having a professional charge the system? i don't think a typical garage setup is capable of recharging from completely empty.
Old 10-08-14, 08:19 PM
edd6499
edd6499's Avatar
I was doing it myself and seems like others have posted on here that they were able to at home after compressor replacement. Have had successi in the past with a Ford after replacing the compressor. I would assume you are correct about low pressure shutting it off but would expect the suction side of the lines to draw it in.
Old 10-09-14, 05:47 AM
billydpowe
billydpowe's Avatar
pull another vacuum, run a bucket of HOT water, hold can upside down in the hot water while filling system.. dont burn yourself.. if you hold the can upright the freon goes in as a liquid, upside down it is a gas, the heat just forces it in the system... that is the cheap way without pro equipment..
Old 10-09-14, 06:20 AM
fixmiester
fixmiester's Avatar
Default System charging
Make sure that you have your charging hose properly oriented ; there should be a center post inside the connector that depresses the Schrader valve when you screw it on. Otherwise you will have problems getting the freon through the valve.
Old 10-09-14, 12:16 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
i don't see how you can get an R12 can to even fit onto the fittings since all shops nowadays sell R134 cans which have completely different sized fittings. they do make retrofit kits to convert your fittings.
Old 10-09-14, 03:40 PM
cgawelko
cgawelko's Avatar
You can still get R12, its not that hard. People here do it all the time. I even know someone with a professional R12 machine
Old 10-10-14, 03:22 PM
fixmiester
fixmiester's Avatar
Iwill replace the cores with the system fully charged.
LOL, now this I gotta see!
Quick Reply: 1993 LS400 AC Schrader Valve Core Replacement Part
