Power Steering Problem 1.gen. 93'
Hi Lexus forum,
I know there has been a lot of threads about issues with the Power steering, but I have search and search but couldn't find a solution to my problem.
Car: 1993 LS
Problem: The power steering is hard/stiff to turn especially in the last stage just before lock, seems a bit better when the engine is at higher revs.
Things I have done: Rebuildt PS pump with OEM gasket kit and bearing, changed Air control valve on pump to a new OEM. Flushed the system, cleaned the solonoid in the rack and blead the system.
I have no leaks at all.
After these thing I STILL have hard/stiff power steering
I'm really confused at this point, does anybody know of this problem?
I'm kind a thinking High pressure hose, flow control valve or steering damper
Thanks for any replies
Daniel (Denmark)
Car: 1993 LS
Daniel (Denmark)
Maybe Checked the price for the high pressure hose at Lexus here in Denmark. It was about 450 US$ !
I'll try to bleed the system for a looooooooong time, someone said the LS is very difficult to get all the air out of the power steering system.
Does anyone have other suggestions
