Help! Decelleration problem when I let off the gas
I've tried searching for this... I know I've read it somewhere but I can't find the post...
When I let off the gas the car drops in speed instead of coasting smoothly. The gas pedal is very touchy because of this and makes you jerk the car when you press it or let off of the gas.
Can someone tell me what the problem is? Or direct me to the post I'm failing to find...
Okay sorry, its a 98 with 70,000 miles. MY TIRE PRESSURE IS GOOD and it is IN DRIVE!
Its nothing obvious as I am fairly good with cars...
I've read a post about this as a common problem with the 98-00 LS. Any help finding this post would be great.
It does feel as if its in a lower gear than it should be, but it happens at all speeds, almost all the time.
I'll get back to you on that. What should it be at?
Note, it doesn't do it ALL the time, and when it does do it apparently by shifting back to park, then back to drive again helps.
It feels just like when you are in too low of a gear and let off the gas. Then when you press on the gas again it jerks the car.
Larryu
RX - 4th Gen (2016-2022)
1746
09-11-23 09:21 AM
