suspension ls400
Old 02-17-10, 11:14 AM
pinols400
pinols400's Avatar
Default suspension ls400
hello
i want to replace mij air suspension for normal suspension
can someone tell me if the normal suspension from a '91 ls400
fits a '95 ls400
thnx pinols400
Old 02-17-10, 12:30 PM
Schnitz
Schnitz's Avatar
I don't think so.
Try here: http://www.arnottindustries.com/part...id7_pid47.html
Can't really get a better deal for all four.
Old 02-17-10, 06:45 PM
RA40
Super Moderator
Senior Moderator
RA40's Avatar
It might fit but...the stock spring rates and strut valving may not play well together. The UCF1X and 2X were cross compatible in aftermarket coilover systems but putting the UCF2X into a 1X was not possible due to length. The 1X series were shorter basically.
PD would know more.
Old 02-19-10, 07:03 AM
pinols400
pinols400's Avatar
Default suspension ls 400
so i undestand that it is possible to switch my air suspension for '91 normal suspension
Old 02-19-10, 09:16 PM
Lsportline43
Lsportline43's Avatar
Originally Posted by Schnitz
I don't think so.
Are those good for replacement struts/springs for a non-air suspension '95-'00 LS400? Or is it only a conversion kit?
Old 02-19-10, 10:32 PM
RA40
Super Moderator
Senior Moderator
RA40's Avatar
You can probably find some stock springs and use the Bilstein HD's with the top hat. Good ride character with a bit firmer valving and you'll have the lower perch. With stock springs that will give ~1/2" drop.
LSfanboy
04-10-11 03:35 PM
350z
02-05-04 11:05 AM
92sc
12-14-03 08:06 AM
LS/SC
01-05-02 05:24 PM
Quick Reply: suspension ls400
